Author Topic: dwg file invalid?  (Read 5892 times)
Dinosaur
Re: dwg file invalid?
« Reply #15 on: January 12, 2006, 01:15:48 PM »
Someone may want to try opening it with a HEX editor to see if there is any header information at all.  I tried with Crimson and Notepad and there was nothing visible in the header section.
Chuck Gabriel
« Reply #16 on: January 12, 2006, 01:17:06 PM »
That is definitely NOT an AutoCAD drawing.  I opened it in a text editor.  If it was a real .dwg file, the first six bytes would be a human-readable code indicating what version of AutoCAD saved the file.  The first six bytes of your file were garbage.
LE
« Reply #17 on: January 12, 2006, 01:18:06 PM »
There is nothing in there... just blank spaces...
Normally a drawing will start with something like:
AC1015...
SDETERS
« Reply #18 on: January 12, 2006, 01:50:31 PM »
I do not think the file is a DWG file
vinnyg
« Reply #19 on: January 12, 2006, 03:07:37 PM »
Apparently something happened from the last time I opened it and saved it until
I tried to open it again before I posted my question. It was drawn in r14 and saved
as .dwg in r14. What possibly could have happened to it in that period......I don't know!
vinnyg
Dinosaur
« Reply #20 on: January 12, 2006, 03:15:32 PM »
I think a backup file is the only hope for this one.  A HEX editor might be able to create an r14 header but it would be a very long shot.  What happened?  I think there is a very tiny percentage of DOS writes that just fail - sometimes it is a little text file or a temp file that is never needed again and sometimes it nails something important.  In dos days, I would try to save my file, open it immediately and then save again so a good backup could always be found.
Serge J. Gianolla
« Reply #21 on: January 12, 2006, 05:10:36 PM »
Could it be that the header is scrambled! AFAYK, you [or someone else in the firm] did not try something like DOS_Encrypt from DOSLIB to see what happens?
vinnyg
« Reply #22 on: January 12, 2006, 05:44:05 PM »
Serge,
No, I'm the only cad person here. I'm not sure what you mean concerning the
DOS function??
thanks for your input
vinnyg
LE
« Reply #23 on: January 12, 2006, 05:53:01 PM »
Follow the advice Dino... mentioned to you...
Look for the .BAK, or .SV$ - in your temporary folders... appears the only choice... then simple rename the extension to .DWG
HTH
Greg B
  • Tell me a Joke!
« Reply #24 on: January 12, 2006, 05:55:34 PM »
HTH
Ironic how that is possibly what got the file in trouble in the first place.  Changing the extension.
Greg B
  • Tell me a Joke!
« Reply #25 on: January 12, 2006, 05:57:09 PM »
I have a questions...what files does autocad make with the drawings.
For instance....Datacad creates 3 files
.aec  - Drawing File
.png  - Thumbnail Pic
.dbk  - Backup File
LE
« Reply #26 on: January 12, 2006, 06:00:00 PM »
Greg;
Normally if the features on acad are on for AUTOSAVE and the BACKUP copy from each drawing saved.
It will create those extra files... that might help
Greg B
  • Tell me a Joke!
« Reply #27 on: January 12, 2006, 06:03:23 PM »
Greg;
Well now that's not what I'm getting at.  If AutoCAD create's a thumbnail file, it was possible that someone came along and changed the extension of it thinking that it was a backup file.
LE
« Reply #28 on: January 12, 2006, 06:07:14 PM »
AutoCAD does not work that way...
Usable Drawing files:
DWG
BAK
SV$
DWT
DXF
And maybe other(s) that I dont' recall right now...
