Author Topic: Clipping PointCloud?  (Read 1905 times)
matinau
« on: July 29, 2014, 10:45:55 PM »
Does anyone know how to apply a clipping boundary to a PointCloud? The entity itself doesn't have any associated ClipBoundary method and my attempts applying the same logic used to clip BlockReferences does nothing?
I'm guessing pointclouds have their own particular extension dictionaries entries to store this information?
Any help would be great.
lamarn
Re: Clipping PointCloud?
« Reply #1 on: July 30, 2014, 01:49:27 AM »
Put it in a block or xref. Then you can Xclip it.
It would be nice if Xclip had the possibility to control the depth.
However you can XClip in two different XYZ directions to get the area you need.
matinau
« Reply #2 on: July 30, 2014, 03:13:57 AM »
Thanks but that's not really what I after as the PointCloud may not live in a block. To clarify I need to perform the clip using .NET the block approach I referred has been extensively documented online... here's a good one
http://through-the-interface.typepad.com/through_the_interface/2010/11/adding-a-2d-spatial-filter-to-perform-a-simple-xclip-on-an-external-reference-in-autocad-using-net.html
Unfortunately the same cannot be said for PointClouds.
« Last Edit: July 30, 2014, 06:39:15 PM by matinau »
Crank
« Reply #3 on: July 30, 2014, 03:20:49 AM »
2013 and 2014 had the POINTCLOUDCLIP command, but has been removed....
matinau
« Reply #4 on: August 03, 2014, 07:16:44 PM »
For all those interested...
"In order to create a Point Cloud clipping region you must use the C++ ObjectARX API as there is no equivalent .NET API. This is mainly due to performance reasons."
Mr. Fenton Webb
http://adndevblog.typepad.com/autocad/2013/03/creating-a-point-cloud-spatial-filterclipping-box-using-objectarx.html
