Author Topic: Oh the joys of a "high level" language!  (Read 8182 times)
Chuck Gabriel
« on: May 15, 2008, 08:22:46 PM »
Can anybody tell me how to cram an integer (from user input) into an instance of Autodesk.AutoCAD.Windows.OpenFileDialog.OpenFileDialogFlags?
I have gotten a couple of different cast permutations to compile, but they throw an invalid cast exception at runtime.
Here is the whole shooting match for context:
using System;
using System.IO;
using System.Text;
using Autodesk.AutoCAD.Windows;
using ofdFlags = Autodesk.AutoCAD.Windows.OpenFileDialog.OpenFileDialogFlags;
namespace GetFileDialog
    public class Main
        [LispFunction("GetFileDialog")]
        public static ResultBuffer GetFileDialog(ResultBuffer buff)
            if (buff == null)
                ed.WriteMessage("\nToo few arguments.");
                return null;
            ResultBufferEnumerator iter = buff.GetEnumerator();
            iter.MoveNext();
            if (iter.Current.TypeCode != (short)LispDataType.Text)
                ed.WriteMessage("\nGetFileDialog expects arguments of string string string int.");
                return null;
            string title = (string)iter.Current.Value;
            if (iter.MoveNext() == false)
                return null;
                return null;
            string defaultFileName = (string)iter.Current.Value;
                return null;
                return null;
            string defaultExtension = (string)iter.Current.Value;
                return null;
            if (iter.Current.TypeCode != (short)LispDataType.Int16)
                ed.WriteMessage(LispDataType.Int16.ToString());
                return null;
            int flags = (int)iter.Current.Value;
            if (((flags & (int)ofdFlags.DefaultIsFolder) != 0) && Path.HasExtension(defaultFileName))
                defaultFileName = Path.GetDirectoryName(defaultFileName);
            OpenFileDialog ofd = new OpenFileDialog(title, defaultFileName, defaultExtension, title, (ofdFlags)flags);
            if (ofd.ShowDialog() != System.Windows.Forms.DialogResult.OK)
                return null;
            ResultBuffer result = new ResultBuffer();
            foreach (string file in ofd.GetFilenames())
                result.Add(new TypedValue((int)LispDataType.Text, file));
            return result;
Chuck Gabriel
Re: Oh the joys of a "high level" language!
« Reply #1 on: May 15, 2008, 08:29:04 PM »
Here are the casts I've already tried:
(ofdFlags)flags
(ofdFlags)Enum.ToObject(typeof(ofdFlags), flags)
« Reply #2 on: May 15, 2008, 08:36:01 PM »
Chuck, I don't have docs handy at the moment .. but are the fields int16 or int32 ??
tjr
« Reply #3 on: May 15, 2008, 08:50:43 PM »
What int values are you trying to pass to the flags?
It's Alive!
  • Retired
  • AKA Daniel
« Reply #4 on: May 15, 2008, 08:53:04 PM »
//(GetFileDialog "Title" "MyFile" "dwg" 4)
      try
        if (buff == null)
          return null;
        iter.MoveNext();
          return null;
          return null;
          return null;
          return null;
          return null;
          return null;
          return null;
        ofdFlags flags = (ofdFlags)(short)iter.Current.Value;
        if (((flags & ofdFlags.DefaultIsFolder) != 0) && Path.HasExtension(defaultFileName))
        OpenFileDialog ofd = new OpenFileDialog(title, defaultFileName, defaultExtension, title, flags);
          return null;
      catch (System.Exception ex)
        ed.WriteMessage(ex.Message);
        ed.WriteMessage(ex.StackTrace);
      return result;
Edit: removed the extra casts
« Last Edit: May 15, 2008, 09:08:06 PM by Daniel »
Chuck Gabriel
« Reply #5 on: May 15, 2008, 08:53:38 PM »
Int16
In this particular instance, 16.
Thanks for your help you guys.
Chuck Gabriel
« Reply #6 on: May 15, 2008, 08:57:34 PM »
Daniel,
Is that your way of telling me that maybe I should give people a hint about how I intend to call this code?  :-)
« Reply #7 on: May 15, 2008, 08:59:18 PM »
Int16
As Daniels code indicates ..
int32 is int
int16 is short
It's Alive!
  • Retired
  • AKA Daniel
« Reply #8 on: May 15, 2008, 09:01:01 PM »
Daniel,
Hehe :) all you needed to do was cast the value as a short , Kerry spotted it too( but with no debugger)  :-o
Chuck Gabriel
« Reply #9 on: May 15, 2008, 09:22:16 PM »
WooHoo!!!  That's got it.  Thanks guys.  Y'all are the greatest!
It's always something in the minutia that bites me.  It seems to me that some of the "low level" languages are actually much more forgiving than .NET.
Bryco
« Reply #10 on: May 15, 2008, 10:03:11 PM »
It seems to me that some of the "low level" languages are actually much more forgiving than .NET. for me too.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #11 on: May 15, 2008, 10:10:04 PM »
C# (.NET) is strict by design, it’s to prevent security flaws, buffer overruns and such.
Glenn R
« Reply #12 on: May 16, 2008, 04:33:05 AM »
Chuck,
Similar short of thing :) happened in your 'C# HotKeys' thread if memory serves and the solution then was a cast to short as well.
Glad it worked for you and good to see you having a dabble again.
Cheers,
Glenn.
« Reply #13 on: May 16, 2008, 04:49:41 AM »
Chuck,
Similar short of thing :) happened in < snip>
very punny !
Glenn R
« Reply #14 on: May 16, 2008, 04:59:29 AM »
 :lmao:
