CAD Forums > BricsCAD Users
Creating a Dictionary within BricsCAD
(1/1)
theSurveyor:
I'm trying to create a dictionary, using .NET, to hold several values that I will need to use during the life of a drawing. While I have found information on the subject, I have not been able to get the code to work.
Basically, what I want to do is create a dictionary e.g., MyDict and store several keys and values, e.g., "Project", "New", and recall the value of "Project" later on.
I would appreciate any assistance that would allow me to implement the Dictionary.
It's Alive!:
This should be in the .NET section of you want to use .net
Though, if you just want to store a few variables, I recommenced using the custom section in DWGPROPS
it's also easy to access the via API's easily
You can also link fields to these custom properties..
Welcome to the swamp!
theSurveyor:
Thanks for your suggestion. I've used the DWGPROPS before, so I am familiar with the method.
Navigation
[0] Message Index
Go to full version
