Author Topic: How to enter Dynamic Block definition ?  (Read 1470 times)
Coder
« on: December 19, 2011, 05:32:44 AM »
Hello everybody .
I just have noticed that I could not enter the Dynamic Block definition the same way like normal blocks , is there any way to do that ?
I used to use this code to enter block definition ..
(vlax-for blok (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
Many thanks . :-)
Coder
Re: How to enter Dynamic Block definition ?
« Reply #1 on: December 19, 2011, 07:33:03 AM »
I noticed that it can change the color of dynamic blocks definitions only , which means I have to insert the dynamic block to see the changes .
pBe
« Reply #2 on: December 19, 2011, 08:21:33 AM »
I still dont get it   :?
vla-get-EffectiveName???
Coder
« Reply #3 on: December 19, 2011, 10:53:33 AM »
Hi ,
I am trying to change the block's entity's color to specific color , but the attributes not changing in normal blocks and in Dynamic Blocks
« Reply #4 on: December 19, 2011, 01:23:32 PM »
Use AttSync after modifying the ATTDEF entities within the Block Definition.
Or, modify the ATTRIB entities within each INSERT - but remember that any call to AttSync will revert these changes.
