Author Topic: About system environment variables  (Read 2166 times)
2e4lite
« on: July 07, 2014, 10:19:55 PM »
How to get all system environment variables in the drawing and their current settings?
Re: About system environment variables
« Reply #1 on: July 07, 2014, 11:21:12 PM »
Command:
SETVAR
Enter variable name or [?]: ?
Enter variable(s) to list <*>: *
// or
Command: _.sysvdlg
Select SaveAll ...
« Reply #2 on: July 07, 2014, 11:24:45 PM »
2e4lite
« Reply #3 on: July 08, 2014, 01:05:12 AM »
Thank you for your quickly reply!
rkmcswain
« Reply #4 on: July 08, 2014, 09:31:55 AM »
Quote from: 2e4lite
...system environment variables
Quote from: Kerry
SETVAR
Command: _.sysvdlg
OP said environment variables, which are different than "AutoCAD system variables"
If environment variables are really the desire here, see: http://www.hyperpics.com/downloads/resources/customization/autolisp/AutoCAD%20Environment%20Variable%20Quick%20Guide.pdf
« Reply #5 on: July 08, 2014, 01:06:10 PM »
Another (from gile)
dgorsman
« Reply #6 on: July 09, 2014, 12:43:51 PM »
To be finicky, environment variables do not exist for drawings.  System variables, yes.  Some system variables are both.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
« Reply #7 on: July 09, 2014, 07:17:23 PM »
Yep.
And then there is the distinction between variables saved in the drawing and those saved in the profile and those saved in the registry.
... and then there is the fact that the documentation is a little skimpy ... a 9 year old pdf from an independant web site is hardly current documentation.
rkmcswain
« Reply #8 on: July 10, 2014, 07:53:05 AM »
Quote from: Kerry
...and those not saved at all.
