Author Topic: scalelist, scalelistedit etc  (Read 7475 times)
jonesy
  • SuperMod
« on: July 15, 2008, 09:50:52 AM »
More of a general question than needing help.
Where/when did the scalelist and scalelist edit come into being?
I have to admit they are driving me potty, the current drawing I am editing had hundreds of scales in the list, and its no longer a simple thing to select a viewport scale in the properties dialog box. ScalelistDel has made it onto my toolbar so I can keep on top of the pesky things.
Is it just bad planning, a bug, or are they/can they be useful?
Hedgehog
Re: scalelist, scalelistedit etc
« Reply #1 on: July 15, 2008, 10:02:00 AM »
They can be useful when dealing with annotative scaling but in general I find them a pain... there is an Autodesk application to trim down the number of scales on that list... now where is it...  :kewl:
CHulse
« Reply #3 on: July 15, 2008, 10:41:25 AM »
I just made a button to reset the list... PIA.
Cary Hulse
Urban Forestry Manager
Wetland Studies and Solutions
Civil 3D 2020 & 2023
« Reply #4 on: July 15, 2008, 11:19:55 AM »
If you don't use scalelists, why don't you just add the command to startup...then the drawing is "cleaned" on open.
CHulse
« Reply #5 on: July 15, 2008, 12:14:15 PM »
Good Idea.
I like to have the option though...it's not always needed.
Cary Hulse
Big G
« Reply #6 on: July 15, 2008, 10:38:14 PM »
found that sometimes the scalelistedit cmd will throw up an error in c3d 2008 when there is too many scales
-scalelistedit never seems to fail tho
*EDIT*
covered here also http://www.theswamp.org/index.php?topic=23963.0
I thought i seen the light at the end of the tunnel. But it was just someone with a torch bringing me more work.
"You have to accept that somedays youre the pigeon and  somedays youre the statue"
hudster
« Reply #7 on: July 16, 2008, 03:33:40 AM »
I like that in 2009 you can set it up that only your default scales are loaded when you open a drawing.
jonesy
  • SuperMod
« Reply #8 on: July 16, 2008, 08:22:26 AM »
Where do they come from?
It seems like I've constantly got new ones in the scale list.
Crank
« Reply #9 on: July 16, 2008, 09:07:03 AM »
Be sure you have SP1 installed.
The new scale are coming from imported wblocks and xrefs.
If you put the next lisp in your acaddoc.lsp or your .mnl-file all unused scales will be purged:
(defun c:PurgeScales ( / schaallijst n ce dm)
(command ".undo" "begin")
(setq ce (getvar "CMDECHO"))(setvar "CMDECHO" 0)
(setq dm (getvar "DYNMODE"))(setvar "DYNMODE" -3)
(if (and (wcmatch (getvar "CANNOSCALE") "*'*")(not (inPspace)))
(setvar "CANNOSCALE" "1:1")
[color=red](if (> (length (dict-list (dict-name "ACAD_SCALELIST"))) 17)(COMMAND "-SCALELISTEDIT" "R" "Y" "E"))[/color]
(setq schaallijst '())
(foreach n (dict-list (dict-name "ACAD_SCALELIST"))
(setq schaallijst (cons (cdr (assoc 300 (entget (cdr n)))) schaallijst))
(foreach n schaallijst
(if (/= n "1:1")(command ".-scalelistedit" "Delete" n "Exit"))
(setvar "DYNMODE" dm)
(setvar "CMDECHO" ce)
(command ".undo" "end")
(c:PurgeScales)
(defun inPSPACE ()
  (and
    (zerop (getvar "TILEMODE"))
    (zerop (getvar "VPMAXIMIZEDSTATE"))
    (eq (getvar "CVPORT") 1)
;; List A Dictionary As Pairs {Name . Object Name}
(defun dict-list ( dname / d nl ) ;; dname As object name or string else ROOT
((and (setq d (cond
((= 'ENAME (type dname)) dname)
((= 'STR (type dname)) (dict-name dname))
(T (namedobjdict))
(setq d (entget d))
(while (setq d (member (assoc 3 d) d))
(if (or (= 350 (caadr d)) ;; regular dict
(= 360 (caadr d)) ;; extension dict
(setq nl (cons (cons (cdar d) (cdadr d)) nl))
(setq d (cdr d))
(reverse nl)
;; Get Dictionary Object Name From Root Dictionary
(defun dict-name ( name ) ;; name As string or ename of exist dict
( (= 'STR (type name))
(cdr (assoc -1 (dictsearch (namedobjdict) name))))
( (and
(= 'ENAME (type name))
(= "AcDbDictionary" (cdr (assoc 100 (entget name))))
name
Notice that I use 'foreach' twice, because in acad2009 the dictionary changes with every scalelistedit.
« Last Edit: July 19, 2008, 02:19:43 AM by Crank »
jonesy
  • SuperMod
« Reply #10 on: July 16, 2008, 11:30:20 AM »
thanks Crank. I'll take a look at that when I go back to work on Friday
Crank
« Reply #11 on: July 19, 2008, 02:30:27 AM »
I know this can be slow the first time you use it, but once the drawing is saved the useless scales shouldn't return, so the next time it will be a lot faster.
I've added the red line to speed things up a bit for drawings with large scalelists.
I don't know why Autodesk desided to make these long scalelists, because I never use more scales than 4 in a dwg. With these long scalelists you'll have to guess/list what scale you've to use. With only the used scales the drawings are smaller and it's working easier.
Crank
« Reply #12 on: July 19, 2008, 03:06:23 AM »
BTW, to set/make annoscales, you can use this:
(defun c:1:1 ()(MaakSchaal 1))
(defun c:1:2 ()(MaakSchaal 2))
(defun c:1:5 ()(MaakSchaal 5))
(defun c:1:10 ()(MaakSchaal 10))
(defun c:1:20 ()(MaakSchaal 20))
(defun c:1:50 ()(MaakSchaal 50))
(defun c:1:100 ()(MaakSchaal 100))
(defun c:1:200 ()(MaakSchaal 200))
(defun c:1:500 ()(MaakSchaal 500))
(defun c:1:1000 ()(MaakSchaal 1000))
(defun c:1:2000 ()(MaakSchaal 2000))
(defun c:1:5000 ()(MaakSchaal 5000))
(defun c:1:10000 ()(MaakSchaal 10000))
(defun MaakSchaal (waarde / e schaal)
(command ".undo" "be")
(setq schaal (strcat "1:" (itoa waarde)))
(setq e (getvar "EXPERT"))(setvar "EXPERT" 5)
(command ".-scalelistedit" "A" schaal schaal "Exit")
(setvar "EXPERT" e)
(if (inPspace)
(princ "\nThis scale is added to the scalelist.")
; else
(setvar "CANNOSCALE" schaal)
