Author Topic: Error trapping. Question  (Read 2177 times)
Dilan
« on: March 06, 2020, 01:03:15 AM »
Hello.
I get the coordinates of the point:
(setq pt (getpoint "\nPick point to extract surface elevation: "))Then I get the surface level in the coordinates of this point:
(setq lavelTin (vlax-invoke (vlax-ename->vla-object (car (entsel))) 'FindElevationAtXY (car pt) (cadr pt)))
But if the coordinates of my point "pt" out of border surface - I get an error. And it is clear
How can I do so in this case my variable "lavelTin" was equal for example: "out_of_border"?
Thank you all for your attention.
rayakmal
Re: Error trapping. Question
« Reply #1 on: March 06, 2020, 01:58:47 AM »
Hello.
Maybe you can use this:
(if (AND
   (princ "OK")
Dilan
« Reply #2 on: March 06, 2020, 02:06:16 AM »
Not. I get the same error
« Reply #3 on: March 06, 2020, 08:09:49 AM »
I don't use the Verticals, but try this -
  1.     (and
  2.         (setq pt (getpoint "\nPick point to extract surface elevation: "))
  3.         (setq en (car (entsel)))
  4.     )
  5.     (if (vl-catch-all-error-p (setq lavelTin (vl-catch-all-apply 'vlax-invoke (list (vlax-ename->vla-object en) 'FindElevationAtXY (car pt) (cadr pt)))))
  6.         (princ "\nError obtaining elevation.")
  7.         (princ lavelTin)
  8.     )
  9. )
Dilan
« Reply #4 on: March 06, 2020, 04:07:40 PM »
  1.     (and
  4.     )
  7.         (princ lavelTin)
  8.     )
  9. )
thanks. That's what I need.Everything works as it should.
