Author Topic: Change the Dim Style Text Style?  (Read 13303 times)
Re: Change the Dim Style Text Style?
« Reply #15 on: January 02, 2006, 06:31:33 PM »
SHX files etc.
« Reply #16 on: January 02, 2006, 06:41:59 PM »
Well, that's got me stumped ... It works for me on your Drawing.
I'll qualify that .. I used AC2006, 'cause I dont have AC2000. I wonder If thats an issue ?
PS : I used a complete ActiveX solution, assuming that was your requirements.
« Reply #17 on: January 02, 2006, 06:53:49 PM »
This line does not set the current dimstyle
    (vla-put-activedimstyle g:activedocument eachItem)therefor this test fails because the DimTXSTY never changes.
    (if (= (vlax-invoke g:activedocument 'getvariable "DimTXSTY") StyleNameToRename)
Must be a ACAD2000 bug. Don't sweat it. I have the command line version to fall back on.
I'll be installing ACAD2006 this week so I'll be leaving 2000 behind.
Thanks for the help. :-)
« Reply #18 on: January 02, 2006, 06:55:25 PM »
My pleasure Alan.
