Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Polyline length leader with additional text??
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Polyline length leader with additional text?? (Read 2576 times)
donniedrake
Guest
on:
November 12, 2014, 11:53:10 AM »
Anyone have a way to select a polyline, get it's length, put that length plus additional text in a mtext with leader?
The yellow highlighted text in the example is what I'm trying to accomplish.
Logged
Global Moderator
Seagull
Re: Polyline length leader with additional text??
Reply #1 on:
November 12, 2014, 12:06:59 PM »
Do a search. There are plenty of Label programs that can be modified.
Logged
Needs a day job
Reply #2 on:
November 12, 2014, 12:09:12 PM »
And here's a quicky
to put the length.
Code - Auto/Visual Lisp:
[Select]
defun
c:foo
_getlength e l p1 p2
vl-load-com
defun
_getlength
ename
ep
if
vl-catch-all-error-p
setq
ep
vl
catch
all
apply
vlax-curve-getendparam
list
ename
0.0
vlax-curve-getdistatparam
ename ep
if
and
setq
e
entsel
\n
Select object with length: "
setq
p1
cadr
e
setq
e
car
e
if
and
0.0
setq
l
_getlength e
setq
p2
getpoint
p1
\n
Specify leader landing location: "
command
"._mleader"
p1 p2 l
princ
\n
Object does not have length property..."
princ
Last Edit: November 12, 2014, 12:15:31 PM by ronjonp
Logged
ChrisCarlson
Guest
Reply #3 on:
November 12, 2014, 12:10:54 PM »
Wouldn't be to complicated
[Select]
setq
a
car
nentsel
\n
SELECT ENTITY"
if
and
a
setq
aDXF
entget
a
member
cdr
assoc
0
aDXF
"LWPOLYLINE"
"POLYLINE"
"LINE"
"ARC"
progn
setq
a_length
vla
get
length
vlax
ename
vla-object
a
princ
"Not a valid selection"
Then find the mid point (first point of leader), extend it and enter the text.
Logged
donniedrake
Guest
Reply #4 on:
November 12, 2014, 12:26:15 PM »
Side note, I'm a newbie at implementing lisp's other than existing ones. Learning slowly!
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
