Author Topic: Texture map backwards  (Read 8094 times)
Kate M
Re: Texture map backwards
« Reply #15 on: January 09, 2008, 02:38:50 PM »
I'm in 2007, and my Advanced Render Settings palette must be messed up. Help file says that under "Render Context" I should see "Save File", yet my first option is "procedure."
Josh Nieman
« Reply #16 on: January 09, 2008, 02:44:25 PM »
The one below Procedure is "Destination" and that's the one where you specify "Window" and then you can save that as a file... that's how I do it anyways.  I seem to remember a different method of rendering to file when I was using Autocad 2000 in college, though...
Kate M
« Reply #17 on: January 09, 2008, 02:49:11 PM »
That's still extraordinarily annoying. Nothing I've been able to do has come close to the level of detail MJ posted.
Kate M
« Reply #18 on: January 09, 2008, 03:08:14 PM »
Thanks for your help guys, but I have to shelve this now. My main CAD guy was in a car accident last night (he's mostly okay, but shook up and out for the rest of the week), so I've had to take a deep breath, step back, and prioritize. This is now not one.
So unless it's really bugging you :wink:, feel free to return to your regularly scheduled programming.
« Reply #19 on: January 09, 2008, 03:14:21 PM »
Here it is applied to both the front and back wall perhaps incorrect to do so. Anyway, when I bring them into your file they go whack.  My thought is, take these bits that work and get your other geometry.  So I did that and then stripped out the other material that didn't seem to work. I inserted that geometry, and it botched some of your face normals on the way in, however a quick 3drotate command righted that. I needed to do that as I was getting some strange rendering issues with 'force 2 sided' turned on.  You may have a different graphics card and this might not be required, otherwise flipping them 180 about an edge was all that was required, I left the other floors for you to do.
Yes it was really bugging me, and I STILL don't know what was fluxxing it up in your file, however use the attached FWIW
« Last Edit: January 09, 2008, 03:36:22 PM by mjfarrell »
