Author Topic: 'Join' Single Line text into Multi Line Text?  (Read 4195 times)
craigr
« on: August 06, 2012, 02:53:45 PM »
I have some OLD Cad files with 'Sequence Of Operations' that I need to copy into a Text Editor. Other than copying ONE line at a time, is there a way in CAD to convert these to Muliline Text?
craigr
Rob...
Re: 'Join' Single Line text into Multi Line Text?
« Reply #1 on: August 06, 2012, 03:00:26 PM »
As far as I know, not without Express Tools.
CAD Tech
craigr
« Reply #2 on: August 06, 2012, 03:01:59 PM »
I remember the question coming up a LONG time ago, but didn't need it then, so I didn't pay it too much mind.
I did a search here on the Swamp and didn't find anything.
Thanks for the response though.
craigr
« Reply #3 on: August 06, 2012, 04:30:51 PM »
If you have a full version of AutoCAD ..there are quite a few routines to do this. Mine is called t2mt.
craigr
« Reply #4 on: August 06, 2012, 04:32:16 PM »
Yes, Sadly, we use the LT Version - NO CHANCE of ever changing that here.
craigr
« Reply #5 on: August 06, 2012, 04:44:56 PM »
Well, unfortunately it seems you are relegated to using the old cut and paste method or just retyping.
craigr
« Reply #6 on: August 06, 2012, 04:49:12 PM »
Yes, that is what I guessed. But, I thought it would be worth asking.
I'll have my assistant do the typing, she is MUCH better at it and MUCH faster. - Plus, I don't like to do it. :)
craigr
cadtag
« Reply #7 on: August 06, 2012, 07:51:15 PM »
don't knock typing -- much easier than using a Leroy scriber
If there's a lot of text, and not much else, you _could_ try dxfout, and then edit the dxf file and delete everything other than the verbiage you want.    prolly simpler to re-key it all
sugarCAD
« Reply #8 on: August 14, 2012, 02:04:43 PM »
Download the 30 day trial of Full AutoCAD.
M-dub
« Reply #9 on: August 14, 2012, 02:11:12 PM »
Don't do it, it's a trick!!!
They'll get their hooks in and you will forever be asking your boss to buy you your own legitemate copy.
You're best off just to continue "suffering" with LT... :evil:  ;)
However, this IS another good oportunity to record the hours required to use the "manual" "LT" "work around" and compare it to the seconds it could've taken you with Full AutoCAD.
« Reply #10 on: August 14, 2012, 02:18:50 PM »
Agreed  8-)
M-dub
« Reply #11 on: August 14, 2012, 02:20:10 PM »
Agreed  8-)
Eventually, you WILL have enough justification.  This is fact, it is, it is.
« Reply #12 on: August 14, 2012, 02:40:56 PM »
Agreed  8-)
If craigr's boss hasn't had enough justification in 10 years, I doubt that it will change any time soon.
« Reply #13 on: August 14, 2012, 02:52:50 PM »
I think we've already come to that conclusion  :-P. I still can't wrap my head around why the value of automation isn't seen. Anyhoo ... carry on  :|
