Author Topic: Command line history to txt file  (Read 3174 times)
Bob Wahr
« on: April 10, 2008, 03:38:12 PM »
Anyone have something that echos the command line to a text file?  Not just what was typed in, but the acad prompts, messages, cancels, etc., as well.  Basically, all that you would see when you hit f2.
Re: Command line history to txt file
« Reply #1 on: April 10, 2008, 03:42:48 PM »
If you turn on the system variable 'LogFileMode' then it will.  You can set to path where every you want; 'LogFilePath'.  Will that work?
« Reply #2 on: April 10, 2008, 03:43:19 PM »
I thought turning on logging in config logged all Bob ...
added:
.. too late  .. again :-)
alanjt
  • Standby for witty remark...
« Reply #3 on: April 10, 2008, 03:48:35 PM »
Dropbox
Bob Wahr
« Reply #4 on: April 10, 2008, 03:50:41 PM »
DOH!
Thanks all.
M-dub
« Reply #5 on: April 10, 2008, 03:52:41 PM »
Skeaking of keeping tabs...
Just remember to keep tabs on the destination folder.  Those log files can really add up over time.
« Reply #6 on: April 10, 2008, 03:59:32 PM »
<snip>
Take a nap.
:p
Bob Wahr
« Reply #7 on: April 10, 2008, 04:13:37 PM »
Not actually using it keep tabs as such.  IMO, if you've got someone you need to keep track of that tightly, you've got problems anyway.  We have a really simple CAD test that we give as part of the interview process.  What gets drawn matters, but I can tell more by seeing how they draw it.  I've seen that in the options before but always ignore it as something I don't need.
M-dub
« Reply #8 on: April 11, 2008, 01:56:14 PM »
I completely agree.  Good idea, too.
