Author Topic: What's this Sysbol?  (Read 4047 times)
craigr
What's this Sysbol?
« on: August 27, 2009, 09:58:20 AM »
We came across the dwg from and outside source. It is of an Air Handler.
What is this symbol? The one to the Left is a temperature.
Any ideas?
craigr
« Last Edit: August 27, 2009, 10:02:09 AM by craigr »
Re: What's this Sysbol?
« Reply #1 on: August 27, 2009, 10:08:44 AM »
a filter?
a dehumidifier?
a waffle? ;_)
« Reply #2 on: August 27, 2009, 10:14:24 AM »
Smoke Detector?
Humidity sensor?
What are the others, temp sensor and static pressure?
craigr
« Reply #3 on: August 27, 2009, 10:16:42 AM »
Not a smoke detector, there is one just before it.
On the left is a temperature on the right is a duct static.
I really thought this would be an easy one for you folks.
- I still can't figure it out. (Watch it be something 'easy')
craigr
Matt__W
  • I like my water diluted.
« Reply #4 on: August 27, 2009, 10:32:18 AM »
Didja check the symbol list?   :lol:
Autodesk Expert Elite
« Reply #5 on: August 27, 2009, 10:40:09 AM »
That would be quite a "gotya" :evil:
« Reply #6 on: August 27, 2009, 10:40:48 AM »
How about velocity sensor or UV sterilizer?
Matt__W
« Reply #7 on: August 27, 2009, 10:44:28 AM »
Combination smoke/fire damper?
Shinyhead
« Reply #8 on: August 27, 2009, 10:50:33 AM »
I spent a good bit of time digging through google images and came up empty.
« Reply #9 on: August 27, 2009, 10:52:06 AM »
You did good Chris....
(did that help the empty feelings go away?)
sinc
« Reply #10 on: August 27, 2009, 10:53:23 AM »
My wild guess is humidity sensor.
Shinyhead
« Reply #11 on: August 27, 2009, 10:53:54 AM »
I will try to press on.  :-P
Shinyhead
« Reply #12 on: August 27, 2009, 10:54:22 AM »
My thought as well.
Looks like water drops in the hexagon
Shinyhead
« Reply #13 on: August 27, 2009, 10:55:01 AM »
Any ideas?
craigr
Contact the outside source and ask them what the hell it is.
« Reply #14 on: August 27, 2009, 10:55:47 AM »
or this document: ANSI/ASHRAE Standard 134-2005?
