Author Topic: Revit Architecture 2012  (Read 2495 times)
krampaul82
« on: January 12, 2018, 10:32:01 AM »
To Any Visual Studio 2015 Revit Architecture Experts;
I cannot find the Revit2012Architecture.dll File any where on my computer. I need to reference the revit.dll in a visual studio program.  The SDK is installed along with the Revit Architecture 2011 program.  I can run and edit macros from within revit.  I want to start writing some c# from the Visual Studio 2015 to customize Revit. All of the samples require I use this as a resource. Has the Revit.dll file been renamed?.. am I missing an installation option? any help is appreciated...
(Found Solution Thank you in advance)
« Last Edit: January 12, 2018, 11:41:45 AM by krampaul82 »
MexicanCustard
Re: Revit Architecture 2012
« Reply #1 on: January 12, 2018, 12:47:12 PM »
I'm not sure about 2012 but since 2016 all the DLLs are in the "Program Files/Autodesk/Revit 201?" folder and subfolders for what ever version your running.
krampaul82
« Reply #2 on: January 12, 2018, 02:33:04 PM »
Thank You
krampaul82
« Reply #3 on: January 12, 2018, 02:35:19 PM »
What about installing an add in? I cannot get my add-in-tab to Appear any suggestions?
MexicanCustard
« Reply #4 on: January 12, 2018, 02:50:09 PM »
Are you adding a new tab through an External Application?
krampaul82
« Reply #5 on: January 12, 2018, 03:03:46 PM »
I just want to get the an add in tab to appear by installing a quick add-in the add-in I chose was the sweets applicaton I thought once this was done the  add in tab would appear. it doesn't.
« Last Edit: January 12, 2018, 03:28:08 PM by krampaul82 »
MexicanCustard
« Reply #6 on: January 16, 2018, 07:35:24 AM »
Post what you've got.
krampaul82
« Reply #7 on: January 19, 2018, 11:34:39 AM »
« Last Edit: February 01, 2018, 01:24:25 PM by krampaul82 »
