Not sure what version you're using, but you share my frustration.
Quote from: RenderMan on January 24, 2013, 02:53:02 PMNot sure what version you're using, but you share my frustration. 2012
Are tees and crosses available as OOTB content for 2013? Or is this just Autodesk's way of saying "LOOK WHAT YOU CAN DO!!!" if you can ever figure out the parametric parts building interface.... BWAHAHAHAHAHAAAAA!!!
Quote from: Matt W on January 24, 2013, 03:19:13 PMAre tees and crosses available as OOTB content for 2013? Or is this just Autodesk's way of saying "LOOK WHAT YOU CAN DO!!!" if you can ever figure out the parametric parts building interface.... BWAHAHAHAHAHAAAAA!!!Yes, there are tees, crosses, elbows and valves. The pressure pipes do not use the same part builder, in fact I was able to learn how to create and add a Fire Hydrant in ~ 20 minutes. Downside, only Ductile Iron fittings were released with C3D2013. It's fairly simple (from what I've heard by other users) to add your own classification for PVC or whatever else you need.
Quote from: Jeff_M on January 24, 2013, 04:21:56 PMQuote from: Matt W on January 24, 2013, 03:19:13 PMAre tees and crosses available as OOTB content for 2013? Or is this just Autodesk's way of saying "LOOK WHAT YOU CAN DO!!!" if you can ever figure out the parametric parts building interface.... BWAHAHAHAHAHAAAAA!!!Yes, there are tees, crosses, elbows and valves. The pressure pipes do not use the same part builder, in fact I was able to learn how to create and add a Fire Hydrant in ~ 20 minutes. Downside, only Ductile Iron fittings were released with C3D2013. It's fairly simple (from what I've heard by other users) to add your own classification for PVC or whatever else you need.Just a matter of copying the catalog and renaming a few items in the file
Quote from: mjfarrell on January 25, 2013, 12:42:52 AMQuote from: Jeff_M on January 24, 2013, 04:21:56 PMQuote from: Matt W on January 24, 2013, 03:19:13 PMAre tees and crosses available as OOTB content for 2013? Or is this just Autodesk's way of saying "LOOK WHAT YOU CAN DO!!!" if you can ever figure out the parametric parts building interface.... BWAHAHAHAHAHAAAAA!!!Yes, there are tees, crosses, elbows and valves. The pressure pipes do not use the same part builder, in fact I was able to learn how to create and add a Fire Hydrant in ~ 20 minutes. Downside, only Ductile Iron fittings were released with C3D2013. It's fairly simple (from what I've heard by other users) to add your own classification for PVC or whatever else you need.Just a matter of copying the catalog and renaming a few items in the fileDo you still have to manually modify the *.APC (read .XML) file as we do for 2011, and 2012, or has a pseudo-named Parts Catalog Editor been added in 2013?
