I have a dwg with Room Number & Room Name in the same attribute, but they are each on their own layer. I used the block editor & changed them both to RoomNumbers within Block editor, but the change isn't reflected once I leave the editor.
So, I tried laymrg -it goes thru the process without errors, but doesn't do the merge.
So, I copied one of these blocks to a totally new dwg and did the laymrg and it worked great.
All Layers are Unlocked of course.
Do any of you have any ideas as to what is preventing it in the original dwg?
craigr
