Author Topic: Moving drawing to new template ...  (Read 5562 times)
Hangman
« on: January 15, 2011, 10:59:12 AM »
Good morning everyone.
I have about two hundred drawings that are in need of a major facelift.  We outsourced the project and the company went and used the wrong titleblock, text style, dim style, etc.  Now they claim they did as was instructed and won't fix the package unless they are paid +some for extra time.  Needless to say, we won't be using them again.
Unfortunately, we have two hundred plus drawings we now need to fix.
So in a nutshell, I've been writing a routine that will save the drawing as an original (DrawingName.orig.dwg), then clean up the drawing; take out the old titleblock, change the text style, dim style, etc.
My intention here is to copy everything to the clipboard, open up our template, save it as the drawing file name, paste everything from the clipboard and woalla, we have a clean drawing.
I know I can't run the same LiSP on two different drawings, so I wrote two LiSP's and a VBScript (which was fun 'cause I haven't written one in over a year) to complete this task.
I would prefer having the drawing on a clean template so we won't have to deal with the all the extra text styles, dim styles, and the miscellaeous crap from the outsourced company.
On my way home I started thinking about it some more and I feel there is a better way of doing this, but I can't see it.  I'm using two commands; CopyBase & PasteOrig to copy to the clipboard and paste in the new template.  They work, but I would prefer something else.  Also, I don't care for the idea of a LiSP to run a script to open a template to then run a second LiSP to finish the project.   :|
I have the code at my office PC, so I can't post any yet as I'm not there but when I get back I'll do so.
In the mean time, can you all give me some suggestions and idea's as to a best way to accomplish this task?
Thank you all very much.
[edited] forgot to mention, I'm running Map3D 2010 & 2011 if this info is pertinent for your thoughts.  Thanks.
Hangman  8)
Re: Moving drawing to new template ...
« Reply #1 on: January 15, 2011, 11:12:41 AM »
Offer:
Send me 5+/- buggered drawings, and then the same fixed up to your satisfaction; then another 10 representative buggered drawings as well as your specs / description of problem and solution.
I'll analyze 'em and see if I can come up with a practical strategy / program / batch wrapper to process the whole lot. I've done tons  of batch processing.
Complete confidentiality on everything.
Cost:
Nothing. I'm unemployed. It will give me something useful to do aside from my python course. Down the road there may be some way you can reciprocate.
No worries:
If this doesn't appeal to you for whatever reason feel no obligation to accept the offer.
Maybe:
The swamp could pioneer something along the lines of 'pragmatic bartering'.  :lol:
Just heading out now, so don't interpret my radio silence as me being non responsive.
« Reply #2 on: January 15, 2011, 11:43:15 AM »
why not use the drawing standards tools to swap out the bad text styles and dimension styles?
then run a script to replace the bad titleblocks with the good one and keep the attribute values?
pBe
« Reply #3 on: January 16, 2011, 12:46:51 AM »
What about after redifining Text/Dim Stlyes and the titleblock (pragmatic of course)
issue a wblock, something like this
(defun c:test ()
(setq doc (vla-get-activedocument (vlax-get-acad-object))
      nm    (strcat (substr (vla-get-fullname doc) 1 (- (strlen (vla-get-fullname doc)) 4)) "Fixed"))
  (repeat 4
  (vla-purgeall doc)
(command "-wblock" nm "*")
That way it will still include Layout tabs
will that work?
« Last Edit: January 16, 2011, 01:01:57 AM by pBe »
Hangman
« Reply #4 on: January 17, 2011, 01:57:18 PM »
We are pretty much using the standards tools now, it's just a slow process and I want to automate it.
The real problem is the title block, the outsourced company either dropped in a block and then added Text to the information area (meaning the info is DText objects, not part of the block), or they dropped in the title as an attribute block, but then exploded it and simply added the info to the now exploded attribute text objects that were there.  So the script idea doesn't really work.  Although I'd like to see a script where we could keep the attribute values from an old title block if you have one available.
Quote from: pBe
issue a wblock, ...
This is a thought, I hadn't thought of wblocks to save the Layout tabs.  I'll look into this more, Thank you.
Quote from: MP
Offer:
Send me 5+/- buggered drawings, ...
Thanks Michael, it's a very tempting offer but unfortunately I do not have the authorization to send them out.  I do appreciate the offer though.
By the way, where do you live and do you know ArcGIS ?
Hangman  8)
« Reply #5 on: January 17, 2011, 08:13:08 PM »
No problem + You're welcome + About 14 hours north of Salt Lake City + Unfortunately no.
Hangman
« Reply #6 on: January 18, 2011, 05:47:28 PM »
... About 14 hours north of Salt Lake City ...
Well, ... hmmm, ... I can't help you much in terms of work then, Sorry.   Hang in there though, someth'n will happen.
[edited]  ...  and No, God won't smite you for choosing the wrong religion.  Although, if you ask Him, I'm sure He'll tell you which one is right.   ^-^
« Last Edit: January 18, 2011, 07:33:24 PM by Hangman »
Hangman  8)
« Reply #7 on: January 19, 2011, 08:25:34 PM »
:) Accepted a great offer today, start Monday. :)
do you have his contact info?
Krushert
  • FREE BEER Tomorrow!!
« Reply #8 on: January 19, 2011, 08:43:23 PM »
Congrats are in order so that means MP is buying!   :-D
« Reply #9 on: January 19, 2011, 08:52:58 PM »
« Reply #10 on: January 19, 2011, 08:57:06 PM »
you mean her information, yes ?
« Reply #11 on: January 19, 2011, 08:58:35 PM »
lol, I swear I was going to phrase it that way and knew you would approve :D
Hangman
« Reply #12 on: January 21, 2011, 04:37:51 PM »
Quote from: Kerry
Nope!  HIS information.
1. The words of God, which he spake unto Moses at a time when Moses was caught up into an exceedingly high mountain,
2. And he saw God face to face, and he talked with Him, and the glory of God was upon Moses; therefore Moses could endure His presence.
  From the Exodus
Ahhh, found it.  Here it is:
5. If any of you lack wisdom, let him ask of God, that giveth to all men liberally, and upbraideth not; and it shall be given him.
6. But let him ask in faith, nothing wavering. For he that wavereth is like a wave of the sea driven with the wind and tossed.
  James 1:5
And that my friends, is the way of it.
But let's not digress, I need more help with this issue.
So my LiSP routine calls the script and the script is suppose to open a new file and run another script to finish the process.
The problem I am having is the first LiSP repeats itself and the command from the script is unrecognized.
(from text window)
Command:
Copying everything to Clipboard ... .copybase Specify base point: 0,0,0
Select objects:   9934 found
Select objects:
Command:        So, everything is copied
Resetting System Variables ...
Ending UNDO & Making an UNDO mark ... .undo Current settings: Auto = On,
Control = All, Combine = Yes, Layer = Yes
Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back] <1>: End
Command:
Command: .undo Current settings: Auto = On, Control = All, Combine = Yes, Layer = Yes
Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back] <1>: Mark
Command:
Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back] <1>: Auto
Enter UNDO Auto mode [ON/OFF] <On>: Off
Command:                The system variables have been reset
Command:
Running Script ... _.script
Enter script file name <K:\EFM\documents\5N15B-2_orig.scr>: K:\Stations ...\Support\LiSP\FixDWG.scr
Command:
Closing Drawing & ending function ... nil
Command:        LiSP is restarting
FIXDWG .undo Current settings: Auto = Off, Control = All, Combine = Yes, Layer = Yes
Command:
Command: .undo Current settings: Auto = Off, Control = All, Combine = Yes, Layer = Yes
Enter the number of operations to undo or [Auto/Control/BEgin/End/Mark/Back] <1>: BEgin
Command:
Command:
Setting Drawing Type ...
Drawing type?  'E'lectrical, 'P'iping, 'C'ivil, 'I'nstrumentation, or 'M'odel:
Delay            I have a delay at the beginning of the script file (code below)
Invalid option keyword.
;Script Name: FixDWG.scr
;Author:
;Created:     01/17/2011
;Description: This script automates the execution of the FixDWG LiSP routine.
Delay
1200
Filedia
0
New
"K:\Stations & Facilities\SALT LAKE CITY\Borders\NWP.dwt"
Delay
1800
(FixDWG_Part2)
I can't figure out why the LiSP is repeating itself after the drawing closes and the script doesn't run.
Here's the code for the LiSP (well, part of it, it's 1800 lines):
  (ChangeZeroLengthArcs)
  (CopyAll2Clipboard)
;; Reset System Variables
  (prompt "\nResetting System Variables ... ")
  (setq NWP_acadLTs nil
        LTnotePath nil
        FNnotePath nil
  (setvar "autosnap" origASN)
  (setvar "osmode" origOS)
  (setvar "filedia" origFDia)
  (setvar "cmdecho" origEcho)
  (prompt "\nEnding UNDO & Making an UNDO mark ... ")
  (if (= (eq 8 (logand 8 (getvar "undoctl"))) T)
    (command ".undo" "End" ".undo" "Mark" ".undo" "Auto" "Off")
  (prompt "\nRunning Script ... ")
  (command "_.script" ScriptPath)
  (prompt "\nClosing Drawing & ending function ... ")
;  (command ".close" "Y")  [color=red]I had to comment this out so I could catch the feedback in the text window.[/color]
) ; _function FixDWG
Hangman  8)
LE3
« Reply #13 on: January 21, 2011, 05:29:01 PM »
Kudos ! and good luck sir.
« Reply #14 on: January 21, 2011, 06:49:39 PM »
That is really great news Michael ....  well done !!
