Code Red => .NET => Topic started by: Kerry on December 24, 2006, 03:29:08 AM
If you are installing VS2005 SP1 and you've had the beta installed DON'T forget to uninstall the beta ..
In Add or Remove Programs you may need to select the Show updates toggle so that the previous update <beta> will be show ... pretty hard to find otherwise :-)
... and have the original CD's handy ...
ps: take a packed lunch 'cause it takes a while.
/// kwb
