Author Topic: to draw perpecdicura rectangle on polyline  (Read 1752 times)
dussla
« on: March 31, 2010, 10:10:37 PM »
freinds
sorry many ask  always ~
i met   new problem
that is   to draw  perepcdicura rectangle  on polyline  ,   when i  put a certain  point  on polyline
i tested many perpecdicura routines
but all is failed
if you see  atteched file , you can understand ~
sorry ask~
Re: to draw perpecdicura rectangle on polyline
« Reply #1 on: March 31, 2010, 11:37:19 PM »
I do very little 3D drawing but try the Command rotate3d.
dussla
« Reply #2 on: April 01, 2010, 12:33:26 AM »
yes
cab , thank you for answer
but that is  not 3d
that is  2d window frame  on curve polyline ~
DEVITG
« Reply #3 on: April 03, 2010, 09:24:07 PM »
yes
but that is  not 3d
gile
  • Marseille, France
« Reply #4 on: April 04, 2010, 03:43:43 AM »
Look at the vlax-curve-getFirstDeriv function:
(angle '(0. 0. 0.) (vlax-curve-getFirstDeriv curve paramAtPoint))returns the angle of the curve tangent at the specified param/point.
