Author Topic: HD Serial number  (Read 3162 times)
Marc'Antonio Alessi
  • Marco
Re: HD Serial number
« Reply #15 on: February 04, 2023, 05:02:00 AM »
User beware !
Perhaps or perhaps not :
does the new version have the same problems?
VovKa
  • Ukraine
« Reply #16 on: February 04, 2023, 07:14:22 AM »
do you plan to use this serial in some protection scheme?
It's Alive!
  • Retired
  • AKA Daniel
« Reply #17 on: February 04, 2023, 07:33:21 AM »
Right, it can be changed pretty easily, I know a friend who did that a couple times
Marc'Antonio Alessi
  • Marco
« Reply #18 on: February 04, 2023, 09:13:00 AM »
yes, but I don't have any particular ultra-security needs  :D
drawdraw
  • Mosquito
« Reply #19 on: January 08, 2024, 03:20:19 AM »
Can help to edit the code of Marc'Antonio Alessi, so that it only returns the serial number of the system drive, the drive where the operating system was installed ?
BIGAL
  • 40 + years of using Autocad
« Reply #20 on: January 08, 2024, 06:41:32 PM »
Just a comment, for protection use fas etc as 1st level, ok there is a DOS way to add to all your lisps in 1 go the security check, yes have used it often, so write the checkdisk id as a seperate lisp, using bat file etc copy ser.lsp+lisp1.lsp c:\compilelisps\lisp1.lsp, will have to find again, but security added and compiled 130 lisps in one go. I use (EXIT) in the check as that aborts the current lisp.
Do you know who to make bulk fas files etc. Can use lisp.
Post if want more information.
Personally yes had a phone call software not working, final result was trying to give software to some one else, security worked.
drawdraw
  • Mosquito
« Reply #21 on: January 10, 2024, 12:22:20 AM »
Hi Bigal, appreciate your reply, but I do not really understand what you meant.
Could you elaborate more ?
For me, I use VLIDE, make a project, compiles my lisps into fas.
Then use Make Application to compile all fas into VLX.
Getting hard disk sn is part of security check, make sure user cannot simply copy my VLX and use in other unauthorised pc.
Do you think VLX can be decoded ? Saw someone said can.
Any suggestion, links to build a better security is welcomed.
ribarm
  • Marko Ribar, architect
« Reply #22 on: January 10, 2024, 02:23:37 AM »
Who made compiler, for sure made and decompiler, or knows how decompile works...
But that one for sure isn't interested in viewing our poor coding stuff...
M.R. on Youtube
drawdraw
  • Mosquito
« Reply #23 on: January 10, 2024, 03:16:05 AM »
haha, you are right, just to protect from non-expert.
 :roll:
VovKa
  • Ukraine
« Reply #24 on: January 10, 2024, 07:58:13 AM »
go for mac-address
drawdraw
  • Mosquito
« Reply #25 on: January 10, 2024, 08:22:26 PM »
Thank you very much !
