Author Topic: shaded vport options  (Read 1172 times)
domenicomaria
« on: February 21, 2023, 03:40:07 AM »
Is there a way to set the "shade plot" property and the "quality" property
in "shaded vport options"  in the plot window ?
maybe I should use one of the following functions?
vla-put-ShadePlot, vla-put-OlePlotQuality, vla-put-OLEQuality . . .
VovKa
  • Ukraine
Re: shaded vport options
« Reply #1 on: February 21, 2023, 05:35:00 AM »
vla-put-ShadePlot
it depends on what value you want to set
domenicomaria
« Reply #2 on: February 21, 2023, 07:30:10 AM »
as displayed    and    maximum
VovKa
  • Ukraine
« Reply #3 on: February 21, 2023, 08:28:33 AM »
as displayed
(entmod
  (vk_PutAss 0
        76
        (vk_RemoveAss 333
            (entget
              (vlax-vla-object->ename (vla-get-ActiveLayout (vla-get-ActiveDocument (vlax-get-acad-object))))
domenicomaria
« Reply #4 on: February 21, 2023, 01:44:13 PM »
where are vk_PutAss and vk_RemoveAss ?
and shaded vport quality?
VovKa
  • Ukraine
« Reply #5 on: February 21, 2023, 02:40:39 PM »
these are the simple library functions
anyway, we can do it without them
(entmod
  (append (vl-remove-if (function (lambda (e) (or (= (car e) 76) (= (car e) 333))))
(entget (vlax-vla-object->ename
  '((76 . 0))
domenicomaria
« Reply #6 on: February 21, 2023, 02:59:13 PM »
ok
but why don't you use vla-put-ShadePlot ?
VovKa
  • Ukraine
« Reply #7 on: February 21, 2023, 03:31:16 PM »
i cut this snippet from a bigger function
this is how i did it that time
does vla-put-ShadePlot work in model space?
