Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Change coordinates + export block
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Change coordinates + export block (Read 2137 times)
amc.dicsac
Newt
Autocad 2008
WWW
on:
June 13, 2016, 05:14:53 PM »
Hello that such I need help, I have a block in the coordinates 100,100,50 and want change when exported to 0,0,0
Logged
<a href="http:/http://axprogramlisp.blogspot.pe" class="bbc_link" target="_blank">By Alexander Castro</a>
kdub_nz
Mesozoic keyThumper
SuperMod
Water Moccasin
class keyThumper<T>:ILazy<T>
Re: Change coordinates + export block
Reply #1 on:
June 13, 2016, 05:29:36 PM »
What have you tried that doesn't work ??
Logged
Called Kerry in my other life
I live at UTC + 13.00
amc.dicsac
Newt
Autocad 2008
WWW
Reply #2 on:
June 13, 2016, 05:36:00 PM »
Code - Auto/Visual Lisp:
[Select]
defun
c:Export_Block
Carpeta_dwg Nombre_dwg Punto_base sscop
setq
Carpeta_dwg
"C:/Bloques/"
setq
Nombre_dwg
getstring
t
\n
Ingresa nombre de bloque: "
setq
Path_dwg
strcat
".dwg"
setq
Punto_base
getpoint
\n
>> Indica punto base: "
command
"ucs"
"o"
Punto_base
setq
sscop
ssget
"_:L"
command
"_.-wblock"
Path_dwg
Punto_base sscop
command
"oops"
command
"ucs"
"p"
command
"base"
"0,0,0"
LM:
Open
strcat
".dwg"
princ
;; Abrir Archivos ---> Lee Mac
defun
LM:
Open
target
shell result
if
and
or
eq
'INT
type
target
setq
target
findfile
target
setq
shell
vla-getInterfaceObject
vlax-get-acad-object
"Shell.Application"
progn
setq
result
vl
catch
all
apply
vlax-invoke
list
shell '
open
target
vlax-release-object
shell
not
vl-catch-all-error-p
result
vl-load-com
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
