Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
CAD Forums
CAD General
Topic:
Double Line Type
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Double Line Type (Read 4106 times)
nyah
Guest
Double Line Type
on:
April 13, 2011, 07:12:24 AM »
Hi Cad-Jedi Knights
Is it possible to create a linetype that has a solid line and offset to that by 1.25 a dashed line which together in engineering terms measn a pipe is heat traced or insulated
Solid Line is the Pipe
Dashed Line is the Insulation
Currently using Autocad 2011 LT [[Unfortunately]]
see attached drg
Thanks all
Nyah
Logged
rkmcswain
Swamp Rat
WWW
Re: Double Line Type
Reply #1 on:
April 13, 2011, 08:15:07 AM »
If AutoCAD LT 2011 includes MLINEs, you could use them to do this.
I know LT 2009 did not include support for MLINEs, but I'm not sure about 2011.
I created one in the attached drawing.
Logged
R.K. McSwain
twitter
quagga
Guest
Reply #2 on:
April 13, 2011, 09:07:22 AM »
I don't even think "mlines" are available in AutoCAD Lt 2012. :realmad:
Logged
JCTER
Guest
Reply #3 on:
April 13, 2011, 09:24:43 AM »
Dynamic Block with two lines in it, and a 'stretch' grip? :/
There really is no good way to utilize double/triple lines...even if you have MLINE function included :/
Logged
M-dub
Guest
Reply #4 on:
April 13, 2011, 09:29:27 AM »
I think the easiest way to get
the look
of the result you want would be to draw a pline, then offset it and change the linetype of one of 'em to hidden / dashed.
That's just me, though.
Logged
Seagull
Every Student their own Lesson
WWW
Reply #5 on:
April 13, 2011, 09:56:20 AM »
Or...use Civil 3D and use the desired Pipe Style to draw your insulated pipes.
Logged
nyah
Guest
Reply #6 on:
April 13, 2011, 10:16:55 AM »
Thanks chaps
Some idiot draffie is convinced AcadLT 2011 is the way forward but each time we find ourselves hitting snags this draffie is low on solutions
Nyah
Logged
Print
Pages: [
1
Go Up
« previous
next »
CAD Forums
CAD General
Topic:
Double Line Type
