Author Topic: Best way to Lower File Size  (Read 2436 times)
Kheilmann
« on: September 20, 2007, 11:03:25 AM »
I've cleaned out a lot of my code, and removed old forms, etc.; however, the size of my
files either stay the same or increase.  I remember something about Compile on Command, but
not quite sure what it was.
Thanks in advance for you help
Kevin
Chuck Gabriel
Re: Best way to Lower File Size
« Reply #1 on: September 20, 2007, 11:08:46 AM »
Have you tried exporting all of your forms, modules and class modules, and then rebuilding the project from them?  That will typically get you a smaller dvb file.
« Reply #2 on: September 20, 2007, 11:19:53 AM »
VBA is notorious for maintaining dead code in the file. Use Chuck's resolution and the files should be much smaller.
Guest
« Reply #3 on: September 20, 2007, 11:21:18 AM »
I've noticed that simply doing a SAVE AS creates a much smaller file.
Kheilmann
« Reply #4 on: September 20, 2007, 11:29:02 AM »
Thank You.  Worked well.
Kheilmann
« Reply #5 on: September 20, 2007, 11:34:05 AM »
My VBA (AutoCAD 2006) does not have a SAVE AS, just a SAVE.
Also, there is not a NEW Project.  In order to start a Project from Scratch, I have
to unload all current programs, and then the Global program will be available for me to
start developing.  And when I click "SAVE" here, it asks for location & name; however if the
DVB file was already saved, then it just resaves, there is no option to SAVE AS.
Am I missing something?
Thanks again for all your help.  My file shrunk from 4.8 Mb to 800 KB.
Also, how often should I export & import into a new file?  Seems like there should be
a way to Compile or decompile, etc. ????
Thanks again,
Kevin
Guest
« Reply #6 on: September 20, 2007, 11:36:16 AM »
VBAMAN has a SAVE AS button.
deegeecees
« Reply #7 on: September 20, 2007, 11:44:32 AM »
...there is no option to SAVE AS.
This is what you're missing:
Readme for the Menu Modification Sample
This Readme contains information about the Menu Modification sample.
To Use the Sample
The sample comprises two AutoCAD® VBA project (DVB) files. The acad.dvb
file calls the custom_menu.dvb file.
The sample adds items to the File menu in the AutoCAD VBA integrated development
environment (IDE), creates an AutoCAD menu in the IDE, and creates a toolbar in
AutoCAD®.
To use the sample
1. Start AutoCAD and drag the acad.dvb file into AutoCAD.
2. On the AutoCAD Tools menu, click Macro > Macros.
3. In the Macros dialog box, in the Macro list, select the ACADStartup macro
   in acad.dvb.
4. Click Run.
deegeecees
« Reply #8 on: September 20, 2007, 11:47:37 AM »
Alternately, you could move the files 'acad.dvb', and 'custom_menu.dvb' to a directory in the Acad support path, then they run automatically when AutoCad starts.
