Author Topic: Exit (by pressing Esc) program that has no use input?  (Read 9530 times)
« on: August 08, 2007, 03:02:35 PM »
How would one exit a routine that has no user input?  Once the command is activated, it generates text strings, and see if they can be gotten as a system variable.  If I want to run it during lunch, then cancel it when I get back from lunch I have to exit Acad to stop the routine, and then I don't know what the last string that was tested is.  Hitting escape (more than once even) doesn't do anything.
Here is the code I'm using.  Right now it doesn't let you input the text string to start at.  I will add this feature when I know how to cancel with the escape button.
Thanks in advance.
namespace Test
/// <summary>
/// Description of GetSystemVariablescs.
/// </summary>
public class GetSystemVariablescs
private string UpStringLetters (string Str, int Location) {
if (Location.Equals(0))
return "A" + Str;
else if (string.Compare("Z", Str.Substring(Location - 1, 1)).Equals(0))
return UpStringLetters (Str.Substring(0, Location - 1) + "A" + Str.Substring(Location), (Location - 1));
else if (Str.Length.Equals(1)) {
char tempChar = Str[0];
tempChar = ++tempChar;
return Convert.ToString(tempChar);
else {
char tempChar = Str[Location - 1];
return Str.Substring(0, Location - 1) + Convert.ToString(tempChar) + Str.Substring(Location);
[CommandMethod("PrintVariables")]
public void Main () {
string TestString = "A";
object VarValue;
while (TestString.Length < 30) {
try {
VarValue = AcadApp.GetSystemVariable(TestString);
if (VarValue != null) {
//MessageBox.Show(TestString + " - " + VarValue.ToString());
using (StreamWriter sw = new StreamWriter("C:/MyCustom/VariableList-CSharp.txt", true)) {
sw.WriteLine(TestString + " - " + VarValue.ToString());
catch {}
try {
VarValue = AcadApp.GetSystemVariable("_" + TestString);
catch {}
TestString = UpStringLetters (TestString, TestString.Length);
Re: Exit (by pressing Esc) program that has no use input?
« Reply #2 on: August 08, 2007, 05:33:34 PM »
Thanks Luis, but that doesn't seem to work for me.  But let me play with it and see if I can get it, or something else to work.  At least I have an idea to go off of now.  :-)
LE
« Reply #3 on: August 08, 2007, 05:35:46 PM »
read on the comments by Tony and there is an arx function (name), that you could use too by p/invoke ing.....
« Reply #4 on: August 08, 2007, 05:45:53 PM »
Well I was wrong.  It does stop it, but it doesn't return control to Acad, it just sits there like a zombie.  Have to fix that.
I noticed that also, but wasn't sure if I wanted to go that route, as I haven't played that much with p/invoke.  But I may, let me try some more stuff.
« Reply #5 on: August 09, 2007, 05:56:10 PM »
Doing it the p/invoke way worked.
« Reply #6 on: August 09, 2007, 06:09:45 PM »
New problem now.  It I let the code run for a couple of seconds, then acad turns to 'Not Responding' in task manager, so no way to escape it, so the code doesn't help really.  I need to figure out a way to save a stream, but not close it.
Off to MSDN site for some studying.
« Reply #7 on: August 09, 2007, 06:31:19 PM »
Found how to save the stream, the flush method.  Now I need to see if I can write an error function like I can in lisp, since the only way to stop the process is to kill Acad.
« Reply #8 on: August 10, 2007, 05:35:42 PM »
So it seems like my program is a memory hog.  It keeps eating, and eating..... How can I make it stop?  I don't see a reason for it in my code, but I might be missing something.
Thanks in advance.
namespace Test
/// <summary>
/// </summary>
[DllImport("acad.exe", CallingConvention = CallingConvention.Cdecl, EntryPoint = "acedUsrBrk")]
private static extern int acedUsrBrk();
return "A" + Str;
else {
PromptResult pr = AcadApp.DocumentManager.MdiActiveDocument.Editor.GetString("\n Enter value to start at: ");
string TestString = pr.StringResult;
if (string.Compare(TestString, string.Empty).Equals(0))
return;
TestString = TestString.ToUpper();
object VarValue;
while (acedUsrBrk().Equals(0)) {
try {
sw.WriteLine(TestString + "," + VarValue.ToString());
sw.Flush();
catch {}
try {
sw.WriteLine("_" + TestString + "," + VarValue.ToString());
sw.Flush();
catch {}
sw.WriteLine("** Canceled at [ " + TestString + " ]");
//AcadApp.DocumentManager.MdiActiveDocument.Editor.WriteMessage(TestString);
Glenn R
« Reply #9 on: August 12, 2007, 10:30:57 AM »
So, in a nutshell, you're trying to create a 'brute force' cracking algorithm for sysvars in Acad...or am I missing something..???
If the answer to the above is yes, I have to ask...why...??????
« Reply #10 on: August 12, 2007, 03:39:28 PM »
You are correct Glenn.  It was a challenge I wanted to do with lisp, but it was way to slow, so I figured I would try with C#.  This is just something for a better understand of Acad, and now I want to know why it is sucking so much memory, so that is another learning point to me.
uncoolperson
« Reply #11 on: August 12, 2007, 07:45:33 PM »
didn't we discuss doing something like this awhile ago?
It's Alive!
  • Retired
  • AKA Daniel
« Reply #12 on: August 12, 2007, 11:02:08 PM »
What’s this? Did I hear challenge? Brute force? hmmm
« Reply #13 on: August 13, 2007, 12:11:18 AM »
You mean here?
That is the only way I can find out how to do this.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #14 on: August 14, 2007, 08:15:44 AM »
How many chars are you searching out to ?
