Nothing against Luis, but in general, licensing code from someone,
somewhere, without source, is a very unwise business decision.
There are no reasonable guarantees that bugs will be fixed.
There are no reasonable guarnatees that vendor will continue
to maintain the code and provide updates if changes to the
underlying APIs require it.
There are no reasonable guarantees that the vendor will
always be in business and available.
Licensing components without source, is foolish at best.
If the vendor wants to license the source to you, then
that's another story. Otherwise, and regardless of whose
code it is, I wouldn't go near it.
I understand, I was just in doubt whether to use available ACAD libraries (possibly managed) or to start searching for some other solution.
The trick is - geometry I'm dealing with needs to conform to certain OGIS rules. In that way it's reusable on other platforms, while managed code dealing with it is at the same time easily portable, too. I.e. geometry/functions utilized by AutoCAD also work with, say, Oracle RDBMs (it's just a matter of spatial provider inbetween).
Regards,
Maksim Sestic
I have done several solutions BETTER than the BPOLY command and I do not think there can be one available as an open source or for free.
