Author Topic: Check if blank is an actual (core) command.  (Read 4540 times)
alanjt
  • Standby for witty remark...
« on: March 30, 2011, 03:34:13 PM »
Is it possible to check if a specific command is actually a command (not LISP) within AutoCAD?
eg.
Line command:
(and LINE)
Dropbox
gile
  • Marseille, France
Re: Check if blank is an actual (core) command.
« Reply #1 on: March 30, 2011, 03:49:13 PM »
Using getcname function:
(getcname "line")
« Reply #2 on: March 31, 2011, 07:36:41 AM »
That's a new one to me - merci beaucoup Gilles  8-)
pBe
« Reply #3 on: March 31, 2011, 07:51:57 AM »
unless somewhere alongthe way somebody did this inside a vlx file
(defun sample ()
  (princ "\nHello Swamp")
  (princ))
(vlax-add-cmd "sample" "sample")
(getcname "sample")
"_SAMPLE"
Matt__W
  • I like my water diluted.
« Reply #4 on: March 31, 2011, 08:17:01 AM »
It apparently doesn't work for XPLODE.
Command: (getcname "xplode")
nil
Autodesk Expert Elite
« Reply #5 on: March 31, 2011, 08:27:20 AM »
That's only an alias though:
_$ (getcname "explode")
"_EXPLODE"
alanjt
« Reply #6 on: March 31, 2011, 08:29:07 AM »
(getcname "line")
Thanks, Gile.
"_EXPLODE"
XPlode and Explode are not the same.
« Last Edit: March 31, 2011, 08:38:53 AM by alanjt »
Dropbox
alanjt
« Reply #7 on: March 31, 2011, 08:40:48 AM »
I was playing around with one of those situations where you are forced to use command to visually place something and I scratched this out...
(defun AT:Command (cmd / *error* c e n lst)
  (defun *error* (msg) (and c (setvar 'CMDECHO c)) (reverse lst))
  (setq e (entlast))
  (setq c (getvar 'CMDECHO))
  (setvar 'CMDECHO 1)
  (command cmd)
  (while (eq 1 (logand 1 (getvar 'CMDACTIVE))) (command PAUSE))
  (or (equal (setq n e) (entlast)) (while (setq n (entnext n)) (setq lst (cons n lst))))
  (*error* nil)
Dropbox
pBe
« Reply #8 on: August 28, 2011, 03:10:25 AM »
what about the other way around? check if a command is a lisp?
(defun LC (cmd)
(foreach i (atoms-family 1)
  (if (EQ (strcase cmd) I)
    (print (strcat "Lisp Command Found: " i)))(princ)
(LC "C:sample")
(LC "sample")
(LC "C:XPLODE")
Crank
« Reply #9 on: August 28, 2011, 03:36:01 AM »
(defun LC (cmd)
(LC "C:sample")
(LC "sample")
(LC "C:XPLODE")
In the macros of my CUI , I don't use atoms-family to check if a lisp is present, but I just use:
(if (not c:example)(load "example"))
But now I wonder: Is it possible to check if a command has been added through a .dll , or if the .dll has been loaded ?
gile
  • Marseille, France
« Reply #10 on: August 28, 2011, 04:23:11 AM »
For .NET defined commands, I use getcname too.
pBe
« Reply #11 on: August 28, 2011, 05:53:24 AM »
I undertsand, what i'm getting at is trying to find out if a lisp with the same name as an ALIAS (pgp) is loaded. if somewhere along the way somebody loads a lisp command that  supercedes the ALIAS i would somehow unload it and not the other way around, strange huh?   :-D
Crank
« Reply #12 on: August 28, 2011, 05:57:58 AM »
@ gile: Cool! :mrgreen:
@pBe: Roger
LE3
« Reply #13 on: August 28, 2011, 11:15:52 AM »
I have used this in the past, but from the ARX side:
AcEdCommandStack* pCmdStack = AcEdCommandStack::cast(acrxSysRegistry()->at(ACRX_COMMAND_DOCK));
AcEdCommand *pCmd = pCmdStack->lookupGlobalCmd(_T("CommandName")); // name of the command to look for
Have not tried the C# route but after a quick look appears that there is a wrapper now for the above as: CommandStack - no idea if works or the usage signature.
HTH.-
« Reply #14 on: August 28, 2011, 12:42:32 PM »
Sorry to drag up old code, but I just wanted to notify that the following:
(defun AT:Command ... )
Won't work if the last created entity is an attributed block, e.g.:
_$ (mapcar '(lambda ( x ) (cdr (assoc 0 (entget x)))) (AT:Command "LINE"))
("ATTRIB" "ATTRIB" "SEQEND" "LINE" "LINE" "LINE")
I propose:
(defun AT:Command2 ( cmd / *error* cm e1 e2 e3 ls )
    (defun *error* ( msg ) (if cm (setvar 'CMDECHO cm)) (reverse ls))
    (if (setq e1 (entlast) e2 e1)
        (while (setq e3 (entnext e2)) (setq e2 e3))
        (setq e2 t)
    (setq cm (getvar 'CMDECHO))
    (setvar 'CMDECHO 1)
    (command cmd)
    (while (= 1 (logand 1 (getvar 'CMDACTIVE)))
        (command pause)
    (if (not (equal e1 (entlast)))
        (while (setq e2 (entnext e2)) (setq ls (cons e2 ls)))
    (*error* nil)
Now:
_$ (mapcar '(lambda ( x ) (cdr (assoc 0 (entget x)))) (AT:Command2 "LINE"))
("LINE" "LINE" "LINE")
