Code Red => AutoLISP (Vanilla / Visual) => Topic started by: deep6 on November 07, 2005, 11:22:00 AM
good morning!
i've been dealing with this for too many days. the short story: i want to take a variable that has been extracted from a block, and use it in a simple expression to get a value for changing the scale of a inserting block.
so, i extract the value from the block attribute, it is 408.908 i assign it the variable 'esta'. now i want to divide it by 50 and assign the answer to the variable 'lval' so it should be as simple as writing this code:
(setq lval'(/ esta 50))
but it does not do the math! i think it has to do with the value of 'esta' which is correct but when returned at the command line = "408.908". am i right in thinking it is the quotes that are my problem? how do i get rid of them? please help!
-sean
Read up on the distof function.
Attribute values are always stored as strings. You will need to convert them to numbers. Either integer or reals. ( atof, distof, atoi ) for munber ( angtof ) for angles.
You would need to convert the value back to a string in order to update them block attribute. -David
AH! i knew it was staring me in the face!
thanks!
In addition, you'll need to remove the quote character that is in front of the division expression in order to evaluate that expression:
(setq lval (/ esta 50) )
