Author Topic: Edit a Solid?  (Read 4609 times)
Edit a Solid?
« on: March 10, 2011, 11:49:34 PM »
Newbie when it comes to 3D. Using plain ACAD2006.
I need to move a hole I punched in a Solid, it is on a flange of an I beam.
Will I be better off starting over? Or can I fill the slotted hole with Union.
Or is there abetter way?
Re: Edit a Solid?
« Reply #1 on: March 11, 2011, 12:20:04 AM »
Alan
It's a long time since I've seen 2006 ..
Is the Command SOLIDEDIT available ?
Re: Edit a Solid?
« Reply #2 on: March 11, 2011, 12:28:42 AM »
In AC2011
Command:  SOLIDEDIT
Solids editing automatic checking:  SOLIDCHECK=1
Enter a solids editing option [Face/Edge/Body/Undo/eXit] <eXit>: FACE
Enter a face editing option
[Extrude/Move/Rotate/Offset/Taper/Delete/Copy/coLor/mAterial/Undo/eXit] <eXit>: MOVE
Select faces or [Undo/Remove]: 1 face found.   <<-Select edge rim of hole
Select faces or [Undo/Remove/ALL]:                  <<-Enter
Specify a base point or displacement:               <<-Select
Specify a second point of displacement:           <<-Select
Solid validation started.
Solid validation completed.
[Extrude/Move/Rotate/Offset/Taper/Delete/Copy/coLor/mAterial/Undo/eXit] <eXit>:  EXIT
barc
Re: Edit a Solid?
« Reply #3 on: March 11, 2011, 03:57:55 PM »
SOLIDEDIT will do it, but if its a SLOT you'll need to make sure you select all 4 faces to be moved.  You can make the slot longer or shorter by selecting one round end face and moving it in line with the slot.
SOLIDEDIT > FACE > MOVE
JCTER
Re: Edit a Solid?
« Reply #4 on: March 11, 2011, 04:03:41 PM »
I might have to revisit my habits, but for some reason long ago I got into the habit of drawing a cylinder to fill it, copying it over the required amount, doing a union then a subtract.
I love the solidedit command though, and use it all the time.  Might have to try the other way and see how I like it..
Re: Edit a Solid?
« Reply #5 on: March 11, 2011, 05:05:23 PM »
Thanks the command does exist.
I'll give it a try. :-)
