I was wondering if anybody else has this problem. After I dimension something I want to put a note with it such as "verify in field" or something. So I type at the <>\X verify in field. All goes well. The dims are above the string and the note is below it. OK so now I want to just slightly move the entire text wither right or left of just center. All of a sudden the dims and text show up in the middle of the dimension string causing the string to disapear for that length of text forcing me to draw an extra line to cover it up and make the dimension string look like a continuous line. Anyone with a solution to that.
