Author Topic: Map export error  (Read 1773 times)
bprabhakar001
Map export error
« on: September 23, 2006, 06:25:19 AM »
Dear All,
When I exporting data I found the message  "445 object(s) of 483 selected, exported in 0 sec(s)".  After that when I open the data into arc view I found the same count missing. And also I have observed some table fields values are going wrong.
Please kindly help me to resolve this problem.
Thnaking you,
Prabhakar.B
Re: Map export error
« Reply #1 on: September 23, 2006, 04:09:50 PM »
I'm not sure why you get the result you do. I just exported this file to "test.e00" with Map2007 and this is the result I got:
Command: _mapexport
"483 object(s) of 483 selected, exported in 3 sec(s)"
bprabhakar001
« Reply #2 on: September 23, 2006, 10:48:32 PM »
Thanks for replay, Mr. Jeff I have couple of hundred files. I need to submit shp files to my client. I am facing not only exporting problem, some of the field values also merging. Here we have some layers one by one. We observed in some of the cases it was happened.
Thanking you,
Prabhakar.B
