So Mick,
what would you do with this list?Public Sub VendorA()
Call SetupAndPlot("11x17Draft.pc3", "STANDARDS.ctb", "Business_Letter_(8.50_x_11.00_Inches)", ac1_1, ac0degrees)
ThisDrawing.Plot.PlotToDevice
ThisDrawing.Close (True)
Public Sub Vendor1117()
Call SetupAndPlot("11x17Draft.pc3", "11X17-CHECKSET.ctb", "ANSI_B_(11.00_x_17.00_Inches)", acScaleToFit, ac90degrees)
Public Sub VendorQuickPlotC()
Call SetupAndPlot("OCE DesignJet 750C.pc3", "VENDOR MEDIUM.ctb", "ARCH_expand_C_(24.00_x_18.00_Inches)", acScaleToFit, ac0degrees)
Public Sub VendorQuickPlotD()
Call SetupAndPlot("OCE DesignJet 750C.pc3", "VENDOR MEDIUM.ctb", "ARCH_expand_D_(36.00_x_24.00_Inches)", ac1_1, ac0degrees)
Public Sub TEPQuickPlot11x17()
Public Sub TEPQuickPlotC()
Call SetupAndPlot("OCE DesignJet 750C.pc3", "tep.ctb", "ARCH_expand_C_(24.00_x_18.00_Inches)", acScaleToFit, ac0degrees)
Public Sub TEPQuickPlotD()
Call SetupAndPlot("OCE DesignJet 750C.pc3", "tep.ctb", "ARCH_expand_D_(36.00_x_24.00_Inches)", ac1_1, ac0degrees)
Public Sub TEP9800D()
Call SetupAndPlot("OCE 9800 DesignJet 750C.pc3", "tep.ctb", "ARCH_expand_D_(36.00_x_24.00_Inches)", ac1_1, ac0degrees)
Public Sub TEPDWFD() 'Setups for C size and 11x17 do not exist, need to be created.
Call SetupAndPlot("DWF6 ePlot.pc3", "tep.ctb", "ARCH_full_bleed_D_(36.00_x_24.00_Inches)", ac1_1, ac0degrees)
Public Sub VENDORDWFD() 'Setups for C size and 11x17 do not exist, need to be created.
Call SetupAndPlot("DWF6 ePlot.pc3", "VENDOR MEDIUM.ctb", "ARCH_full_bleed_D_(36.00_x_24.00_Inches)", ac1_1, ac0degrees)
since they are all self contained, would you leave as is or try and compress? All of these are in the same VBA module
