Author Topic: Offset  (Read 6740 times)
It's Alive!
  • Retired
  • AKA Daniel
Re: Offset
« Reply #15 on: January 05, 2010, 06:21:02 PM »
Nice work Sean !
Bryco
Re: Offset
« Reply #16 on: January 09, 2010, 04:12:29 PM »
an offset function, based on Sean's version but updated for 3d
        [CommandMethod("NoPlotOffset")]
        public static void NoPlotOffset()
            Document doc = acadApp.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            Database db = doc.Database;
            PromptEntityOptions peo = new PromptEntityOptions("\nSelect object to offset");
            PromptEntityResult per = ed.GetEntity(peo);
            if (per.Status != PromptStatus.OK) return;
            ObjectIdCollection ids = Offset(per.ObjectId);
            if (ids.Count == 0) return;
            //Use your layer function here
            string layer=Layers.Layers.AddLayer("T-Invisible");
                foreach (ObjectId id in ids)
                    Curve curve = (Curve)tr.GetObject(id, OpenMode.ForWrite);
                    curve.Layer = layer;
                tr.Commit();
        public static ObjectIdCollection Offset(ObjectId id)
            ObjectIdCollection curveIds = new ObjectIdCollection();
            if (!id.ObjectClass.IsDerivedFrom(RXClass.GetClass(typeof(Curve)))
                || id.ObjectClass == RXClass.GetClass(typeof(Leader)))
                ed.WriteMessage("\nCannot offset that object");
                return curveIds;
            PromptDistanceOptions pdo = new PromptDistanceOptions("\nSpecify the offset distance:");
            pdo.DefaultValue = Math.Abs((double)acadApp.GetSystemVariable("offsetdist"));
            pdo.AllowZero = false;
            PromptDoubleResult pdr = ed.GetDistance(pdo);
            if (pdr.Status != PromptStatus.OK) return curveIds;
            double offset = pdr.Value;
            //To prevent snapping off screen.
            Int16 OsmodeCurrent = (Int16)acadApp.GetSystemVariable("osmode");
            acadApp.SetSystemVariable("osmode", 0);
            PromptPointOptions ppo = new PromptPointOptions
                ("\nSpecify a point on side to offset:");
            PromptPointResult ppr = ed.GetPoint(ppo);
            if (ppr.Status != PromptStatus.OK) goto skip;
            acadApp.SetSystemVariable("offsetdist", offset);
            DBObjectCollection dbo =new DBObjectCollection();
                Curve curve = (Curve)tr.GetObject(id, OpenMode.ForRead);
                Point3d PickPt = ppr.Value.TransformBy(ed.CurrentUserCoordinateSystem);
                Vector3d v = ed.GetCurrentView().ViewDirection.GetNormal();
                Plane plane;
                try
                    plane = curve.GetPlane();
                catch (System.Exception)
                    MessageBox.Show("The selected object cannot be offset."
                    +"To offset an object, all points in the object must be located in the same plane.",
                        "Offset-Object Is Non Planer",MessageBoxButtons.OK,MessageBoxIcon.Warning);
                    goto skip;
                PickPt = PickPt.Project(plane, v);
                Point3d ClosestPt = curve.GetClosestPointTo(PickPt, plane.Normal, false);
                BlockTableRecord space = tr.GetObject
                    (db.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
                double rot = Math.PI * 0.5;
                if (curve.GetType() == typeof(Line))
                    rot = -rot;
                Vector3d xaxis = plane.GetCoordinateSystem().Xaxis;
                Vector3d v3d = curve.GetFirstDerivative(ClosestPt).RotateBy(rot, plane.Normal);
                Double ang = v3d.GetAngleTo(ClosestPt.GetVectorTo(PickPt), xaxis);
                if (ang > Math.PI * 0.5 && ang < (Math.PI * 2) - 0.00001)
                    dbo = curve.GetOffsetCurves(offset);
                else
                    try
                        dbo = curve.GetOffsetCurves(-offset);
                        goto skip;
                if (dbo.Count == 0)
                    goto skip;
                foreach (Entity e in dbo)
                    curveIds.Add(space.AppendEntity(e));
                    tr.AddNewlyCreatedDBObject(e, true);
                tr.Commit();
            } //using
        skip:
            acadApp.SetSystemVariable("osmode", OsmodeCurrent);
            return curveIds;
        }// end Offset
