Author Topic: Using addspline in IntelliCAD 6.1  (Read 2563 times)
oldwoodworker
« on: January 10, 2006, 06:02:57 PM »
As a New Year's resolution I am committed to moving from 2D to 3D CAD, and from CAD scripts and the command line to VBA.  Please excuse a very basic (no pun intended) question.
Would anyone have a generic example of the addspline method in use in either IntelliCAD or AutoCAD.
Pat
Swift
Re: Using addspline in IntelliCAD 6.1
« Reply #1 on: January 10, 2006, 06:43:11 PM »
Have a look at this
'modified from the ACAD 2006 Helpfiles
Option Explicit
Public Sub drawSpline()
    Dim splineObj As AcadSpline
    Dim startTan(0 To 2) As Double
    Dim endTan(0 To 2) As Double
    Dim fitPoints(0 To 8) As Double
    startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
    endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
    fitPoints(0) = 1: fitPoints(1) = 1: fitPoints(2) = 0
    fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0
    fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
    Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
    ZoomAll
oldwoodworker
« Reply #2 on: January 11, 2006, 12:02:59 PM »
Thanks.
I will see if I can feed it from my Excel spreadsheet and make it work in IntelliCAD.  I'll return the resulting code when I get it to work.
Pat
