Author Topic: C++ to lisp  (Read 9841 times)
pedroantonio123
C++ to lisp
« on: December 01, 2014, 05:45:00 AM »
Hi
Can someone please help translate the  C ++ code in Lisp.
There is a code to go from UTM Coordinates to lang long.
Thanks for the Help
PedroAntonio
public static void ToLatLon(double utmX, double utmY, string utmZone)
        double latitude = 0;
        double longitude = 0;
        bool isNorthHemisphere = utmZone.Last() >= 'N';
        var diflat = -0.00066286966871111111111111111111111111;
        var diflon = -0.0003868060578;
        var zone = int.Parse(utmZone.Remove(utmZone.Length - 1));
        var c_sa = 6378137.000000;
        var c_sb = 6356752.314245;
        var e2 = Math.Pow((Math.Pow(c_sa, 2) - Math.Pow(c_sb, 2)), 0.5) / c_sb;
        var e2cuadrada = Math.Pow(e2, 2);
        var c = Math.Pow(c_sa, 2) / c_sb;
        var x = utmX - 500000;
        var y = isNorthHemisphere ? utmY : utmY - 10000000;
        var s = ((zone * 6.0) - 183.0);
        var lat = y / (6366197.724 * 0.9996); // Change c_sa for 6366197.724
        var v = (c / Math.Pow(1 + (e2cuadrada * Math.Pow(Math.Cos(lat), 2)), 0.5)) * 0.9996;
        var a = x / v;
        var a1 = Math.Sin(2 * lat);
        var a2 = a1 * Math.Pow((Math.Cos(lat)), 2);
        var j2 = lat + (a1 / 2.0);
        var j4 = ((3 * j2) + a2) / 4.0;
        var j6 = (5 * j4 + a2 * Math.Pow((Math.Cos(lat)), 2)) / 3.0; // saque a2 de multiplicar por el coseno de lat y elevar al cuadrado
        var alfa = (3.0 / 4.0) * e2cuadrada;
        var beta = (5.0 / 3.0) * Math.Pow(alfa, 2);
        var gama = (35.0 / 27.0) * Math.Pow(alfa, 3);
        var bm = 0.9996 * c * (lat - alfa * j2 + beta * j4 - gama * j6);
        var b = (y - bm) / v;
        var epsi = ((e2cuadrada * Math.Pow(a, 2)) / 2.0) * Math.Pow((Math.Cos(lat)), 2);
        var eps = a * (1 - (epsi / 3.0));
        var nab = (b * (1 - epsi)) + lat;
        var senoheps = (Math.Exp(eps) - Math.Exp(-eps)) / 2.0;
        var delt = Math.Atan(senoheps / (Math.Cos(nab)));
        var tao = Math.Atan(Math.Cos(delt) * Math.Tan(nab));
        longitude = (delt / Math.PI) * 180 + s;
        latitude = (((lat + (1 + e2cuadrada * Math.Pow(Math.Cos(lat), 2) - (3.0 / 2.0) * e2cuadrada * Math.Sin(lat) * Math.Cos(lat) * (tao - lat)) * (tao - lat))) / Math.PI) * 180; // era incorrecto el calculo
        Console.WriteLine("Latitud: " + latitude.ToString() + "\nLongitud: " + longitude.ToString());
Jeff H
Re: C++ to lisp
« Reply #1 on: December 01, 2014, 06:50:53 AM »
It looks like you have a C# snippet and not C++
irneb
Re: C++ to lisp
« Reply #2 on: December 01, 2014, 07:30:42 AM »
Correct! That's definitely NOT C++. The use of var already shows something's different, if it was C++ (and only the newest C++) a similar idea would have used auto instead of var. But the clincher is the use of the Math library for the Pow method, if it was C++ it would have been a situation of adding a include clause for std::pow or math.h and then simply a function call to pow instead (not to mention if it was an object oriented library then it should have been Math->Pow instead of Math.Pow).
Anyhow, to get back to the OP's request, here's a start to show you the general idea of a direct translation:
  1. (defun ToLatLon (utmX utmY utmZone)
  2.   (setq latitude 0.0
  3.         longitude 0.0
  4.         isNorthHemisphere (wcmatch utmZone "*[Nn]")
  5.         diflat -0.00066286966871111111111111111111111111
  6.         diflon -0.0003868060578
  7.         zone (atoi (substr utmZone 1 (1- (strlen utm))))
  8.         c_sa 6378137.0
  9.         c_sb 6356752.314245
  10.         e2 (/ (expt (- (expt c_sa 2) (expt c_sb 2)) 0.5) c_sb)
  11.         ;; Carry on with same principles - the in-line maths are simply changed to polish notation
  12.   )
  13.   (princ "\nLatitud: ")
  14.   (princ latitude)
  15.   (princ "\nLongitud: ")
  16.   (princ longitude)
  17. )
Just carry on doing th exact same things for the other variables also.
Edit: Just to ensure your Lisp code doesn't screw up something else - you would need to localize those variables. For an explanation of how and why see Lee's tut on the subject: http://www.lee-mac.com/localising.html
And a quick way to get VLIDE to help you localize them: http://www.lee-mac.com/quicklocalising.html
« Last Edit: December 01, 2014, 08:03:21 AM by irneb »
Re: C++ to lisp
« Reply #3 on: December 01, 2014, 09:09:39 AM »
This may be of interest.
https://github.com/jl2/utm/
irneb
Re: C++ to lisp
« Reply #4 on: December 01, 2014, 09:22:51 AM »
Very nice! Not to mention it does the reverse also: LatLon->UTM.
Though it's written in Common Lisp. Some of those things aren't available for AutoLisp - I mean stuff like the setf and hash tables would need to be a setq (i.e. re-create the entire list each time instead of just setting an item in it) and a normal association list. But the rest should be easy to translate to AL as is.
ymg
Re: C++ to lisp
« Reply #5 on: December 01, 2014, 11:31:05 AM »
There is also the proj.lsp library by David Allison in Autolisp which can be downloaded
here:  http://www.usouthal.edu/geography/allison/mappro/mappro.zip
Does Transverse Mercator, Polyconic, Lambert Conformal Conic, Alber's Equal Area, and Mercator.
ymg
pedroantonio123
Re: C++ to lisp
« Reply #6 on: December 02, 2014, 01:53:54 AM »
Thanks for the help. I tried the convert. Everything I have not done. Can someone please help me?
(setq e2cuadrada (expt e2 2))
(setq c (/ (expt c_sa 2) c_sb)
(setq x (- utmX 500000))
(setq y (if isNorthHemisphere (/ utmY (- utmY 10000000))))
(setq s (- (* zone 6.0) 183.0))
(setq lat (/ y (* 6366197.724 0.9996)))
(setq v (* (/ c (expt (+ 1 (* e2cuadrada (expt (cos lat) 2) 0.5)) 0.9996))
        var a = x / v;
(setq a (/ x v))
(setq a1 (sin (* 2 lat)))
(setq a2 (* a1 (expt (cos lat) 2)))
(setq j2 (+ lat (/ a1 2.0)))
(setq j4 (/ (+ (* 3 j2) a2) 4.0))
(setq j6 (/ (+ (* 5 j4) (* a2 (expt (cos lat) 2))) 3.0))
(setq alfa (* (/ 3.0 4.0) e2cuadrada))
(setq beta (* (/ 5.0 3.0) (expt alpfa 2)))
(setq gama (* (/ 35.0 27.0) (expt alfa 3)))
(setq bm (* 0.9996 c (- (+ (- lat (* alfa j2)) (* beta j4)) (* gama j6))))
(setq b (/ (- y bm) v))
(setq epsi (* (/ (* e2cuadrada (expt a 2)) 2.0) (expt (cos lat) 2)))
(setq eps (* a (- 1 (/ epsi 3.0))))
(setq nab (+ (* b (1- epsi)) lat))
(setq senoheps    (/ ????
(setq delt (/ ???)
(setq tao (* ???
(setq longitude (+ (* (/ delt pi) 180) s))
(setq latitude ????
irneb
Re: C++ to lisp
« Reply #7 on: December 02, 2014, 02:34:51 AM »
Here's one error in that translation. The C# conditional operator is like a Lisp if statement - the piece following ? is the then portion, and the piece following the : is the else portion. So the translation should rather be:
  1. ;; var y = isNorthHemisphere ? utmY : utmY - 10000000;
  2. (setq y (if isNorthHemisphere utmY (- utmY 10000000)))
irneb
Re: C++ to lisp
« Reply #8 on: December 02, 2014, 03:12:52 AM »
Also, if you've got issues with converting infix notation to prefix (i.e Polish / s-expressions) for Lisp. You could try my Lisp code to do those things for you: http://www.theswamp.org/index.php?topic=41681.10
Just note I have found some errors in it before. I cannot guarantee that it works in every single instance - though it "should"  :wink:
As an example, here's that long line you're having problems with:
_$ (infix->prefix '(((((lat + (1 + e2cuadrada * Cos(lat) ^ 2) - (3.0 / 2.0) * e2cuadrada * Sin(lat) * Cos(lat) * (tao - lat)) * (tao - lat))) / PI) * 180))
(* (/ (* (+ LAT (- (+ 1 (* E2CUADRADA (^ (COS LAT) 2))) (* (/ 3.0 2.0) (* E2CUADRADA (* (SIN LAT) (* (COS LAT) (- TAO LAT))))))) (- TAO LAT)) PI) 180)
Note I had to do a bit of altering in there - e.g. Changing the Math.Pow into ^ and Math.Sin into Sin. Else it went all haywire.
Thereafter the ^ function is simply expt. So you either add something like this:
Or you find-n-replace all ^ with expt in that line.
pedroantonio123
Re: C++ to lisp
« Reply #9 on: December 04, 2014, 02:08:15 AM »
Thanks for the help. There are still 3 lines to translate. Can anyone help me with this yet?
Thank you  :-P  :-D
(setq delt (/ ???)
(setq tao (* ???
irneb
Re: C++ to lisp
« Reply #10 on: December 04, 2014, 02:54:44 AM »
First you need to know those functions. E.g. C#'s Math.Exp raises the math constant e to the specified power: http://msdn.microsoft.com/en-us/library/system.math.exp(v=vs.110).aspx
The same function in AutoLisp is simply exp: http://help.autodesk.com/view/ACD/2015/ENU/?guid=GUID-FD0C918B-A162-4939-9F4E-FFE8863C3FC8
Same goes for:
Unfortunately AutoLisp doesn't come standard with the tan function. But it's reasonably easy to make one yourself. Basically tan = sin/cos. So
  1. (defun tan (x) (/ (sin x) (cos x)))
Though that means you run the risk of getting a divide-by-zero error on angles like 90 degrees. So a safer way might be:
  1. (defun tan (x / c)
  2.    (if (= (setq c (cos x)) 0.0)
  3.       (* (if (< x 0) -1 1) 1.7976931348623158e+308) ;Closest we can get to infinity using a double floating point
  4.       (/ (sin x) c)))
Then those 3 lines are:
  1. (setq senoheps (/ (- (exp eps) (exp (- eps))) 2.0))
  2. (setq delt (atan (/ senoheps (cos nab))))
  3. (setq tao (atan (* (cos delt) (tab nab))))
pedroantonio123
Re: C++ to lisp
« Reply #11 on: December 05, 2014, 07:19:05 AM »
Hello, I have now assembled everything.
It also works without error but the result is not correct.
 (ToLatLon 451602.19 4519076.99 "33N")
should Latitud: 40.821287 Longitud; 14.426080
but with (ToLatLon) Result is Latitud: 40.5467 Longitud: 14.4284
Can someone please check the code C#. Whether this outputs the correct result  :evil: :-P :oops: :cry: :-D
Lisp Code
(defun tan (x / c)
(/ (sin x) c)
        (setq latitude 0.0)
  (setq longitude 0.0)
    ;;bool isNorthHemisphere = utmZone.Last() >= 'N';
(setq isNorthHemisphere (wcmatch utmZone "*[Nn]"))
    ;;var diflat = -0.00066286966871111111111111111111111111;
        (setq diflat -0.00066286966871111111111111111111111111)
    ;;var diflon = -0.0003868060578;
(setq diflon -0.0003868060578)
    ;;var zone = int.Parse(utmZone.Remove(utmZone.Length - 1));
(setq zone (atoi (substr utmZone 1 (1- (strlen utmZone)))))
    ;;var c_sa = 6378137.000000;
(setq c_sa 6378137.0)
    ;;var c_sb = 6356752.314245;
(setq c_sb 6356752.314245)
    ;;var e2 = Math.Pow((Math.Pow(c_sa, 2) - Math.Pow(c_sb, 2)), 0.5) / c_sb;
(setq e2 (/ (expt (- (expt c_sa 2.0) (expt c_sb 2.0)) 0.5) c_sb))
    ;;var e2cuadrada = Math.Pow(e2, 2);
(setq e2cuadrada (expt e2 2.0))
    ;;var c = Math.Pow(c_sa, 2) / c_sb;
(setq c (/ (expt c_sa 2.0) c_sb))
    ;;var x = utmX - 500000;
    ;;var y = isNorthHemisphere ? utmY : utmY - 10000000;
    ;;var s = ((zone * 6.0) - 183.0);
    ;;var lat = y / (6366197.724 * 0.9996); // Change c_sa for 6366197.724
    ;;var v = (c / Math.Pow(1 + (e2cuadrada * Math.Pow(Math.Cos(lat), 2)), 0.5)) * 0.9996;
(setq v (* (/ c (expt (+ 1 (* e2cuadrada (expt (cos lat) 2) )) 0.5) ) 0.9996))
    ;;var a = x / v;
(setq a (/ x v))
    ;;var a1 = Math.Sin(2 * lat);
(setq a1 (sin (* 2.0 lat)))
    ;;var a2 = a1 * Math.Pow((Math.Cos(lat)), 2);
(setq a2 (* a1 (expt (cos lat) 2.0)))
    ;;var j2 = lat + (a1 / 2.0);
    ;;var j4 = ((3 * j2) + a2) / 4.0;
(setq j4 (/ (+ (* 3.0 j2) a2) 4.0))
    ;;var j6 = (5 * j4 + a2 * Math.Pow((Math.Cos(lat)), 2)) / 3.0;
(setq j6 (/ (+ (* 5.0 j4) (* a2 (expt (cos lat) 2.0))) 3.0))
    ;;var alfa = (3.0 / 4.0) * e2cuadrada;
    ;;var beta = (5.0 / 3.0) * Math.Pow(alfa, 2);
(setq beta (* (/ 5.0 3.0) (expt alfa 2.0)))
    ;;var gama = (35.0 / 27.0) * Math.Pow(alfa, 3);
(setq gama (* (/ 35.0 27.0) (expt alfa 3.0)))
    ;;var bm = 0.9996 * c * (lat - alfa * j2 + beta * j4 - gama * j6);
(setq bm (* 0.9996 c (- lat (+ (* alfa j2) (* beta j4)) (* gama j6))))   ;;;not shore
    ;;var b = (y - bm) / v;
    ;;var epsi = ((e2cuadrada * Math.Pow(a, 2)) / 2.0) * Math.Pow((Math.Cos(lat)), 2);
(setq epsi (* (/ (* e2cuadrada (expt a 2.0)) 2.0) (expt (cos lat) 2.0)))
    ;;var eps = a * (1 - (epsi / 3.0));
    ;;var nab = (b * (1 - epsi)) + lat;
    ;;var senoheps = (Math.Exp(eps) - Math.Exp(-eps)) / 2.0;
    ;;var delt = Math.Atan(senoheps / (Math.Cos(nab)));
    ;;var tao = Math.Atan(Math.Cos(delt) * Math.Tan(nab));
(setq tao (atan (* (cos delt) (tan nab))))
    ;;longitude = (delt / Math.PI) * 180 + s;
(setq longitude (+ (* (/ delt pi) 180.0) s))
    ;;latitude = (((lat + (1 + e2cuadrada * Math.Pow(Math.Cos(lat), 2) - (3.0 / 2.0) * e2cuadrada * Math.Sin(lat) * Math.Cos(lat) * (tao - lat)) * (tao - lat))) / Math.PI) * 180; // era incorrecto el calculo
(setq latitude (* (/ (+ lat (* (- (+ 1 (* e2cuadrada (expt (cos lat) 2.0))) (* (/ 3.0  2.0) e2cuadrada (sin lat) (cos lat) (- tao lat))) (- tao lat))) pi) 180.0))
    (princ latitude)
    (princ longitude)
irneb
Re: C++ to lisp
« Reply #12 on: December 06, 2014, 08:00:17 AM »
Nope, it seems as if the C# code is running it properly. E.g. running this in MonoDevelop in Linux:
Code - C#: [Select]
  1. using System;
  2.
  3. namespace ToLatLon_Test
  4. {
  5.         class MainClass
  6.         {
  7.                 public static void Main(string[] args)
  8.                 {
  9.                         Console.WriteLine("UTM to LatLon test");
  10.                         string input;
  11.                         double utmX, utmY;
  12.                         string Zone;
  13.                         try {
  14.                                 Console.Write("Enter utmX: ");
  15.                                 input = Console.ReadLine();
  16.                                 utmX = double.Parse(input);
  17.                                 Console.Write("Enter utmY: ");
  18.                                 input = Console.ReadLine();
  19.                                 utmY = double.Parse(input);
  20.                                 Console.Write("Enter UTM Zone: ");
  21.                                 Zone = Console.ReadLine();
  22.                                 Console.WriteLine();
  23.                                 ToLatLon(utmX, utmY, Zone);
  24.                         } catch(Exception e) {
  25.                                 Console.Write("Error: ");
  26.                                 Console.WriteLine(e.Message);
  27.                         }
  28.                 }
  29.
  30.                 public static void ToLatLon(double utmX, double utmY, string utmZone)
  31.                 {
  32.                         double latitude = 0;
  33.                         double longitude = 0;
  34.
  35.                         // Changed from utmZone.Last as the Linq version is much slower than simply indexing
  36.                         // the last position in the string's array of characters
  37.                         bool isNorthHemisphere = utmZone[utmZone.Length-1] >= 'N';
  38.
  39.                         var diflat = -0.00066286966871111111111111111111111111;
  40.                         var diflon = -0.0003868060578;
  41.
  42.                         var zone = int.Parse(utmZone.Remove(utmZone.Length - 1));
  43.                         var c_sa = 6378137.000000;
  44.                         var c_sb = 6356752.314245;
  45.                         var e2 = Math.Pow((Math.Pow(c_sa, 2) - Math.Pow(c_sb, 2)), 0.5) / c_sb;
  46.                         var e2cuadrada = Math.Pow(e2, 2);
  47.                         var c = Math.Pow(c_sa, 2) / c_sb;
  48.                         var x = utmX - 500000;
  49.                         var y = isNorthHemisphere ? utmY : utmY - 10000000;
  50.
  51.                         var s = ((zone * 6.0) - 183.0);
  52.                         var lat = y / (6366197.724 * 0.9996); // Change c_sa for 6366197.724
  53.                         var v = (c / Math.Pow(1 + (e2cuadrada * Math.Pow(Math.Cos(lat), 2)), 0.5)) * 0.9996;
  54.                         var a = x / v;
  55.                         var a1 = Math.Sin(2 * lat);
  56.                         var a2 = a1 * Math.Pow((Math.Cos(lat)), 2);
  57.                         var j2 = lat + (a1 / 2.0);
  58.                         var j4 = ((3 * j2) + a2) / 4.0;
  59.                         var j6 = (5 * j4 + a2 * Math.Pow((Math.Cos(lat)), 2)) / 3.0; // saque a2 de multiplicar por el coseno de lat y elevar al cuadrado
  60.                         var alfa = (3.0 / 4.0) * e2cuadrada;
  61.                         var beta = (5.0 / 3.0) * Math.Pow(alfa, 2);
  62.                         var gama = (35.0 / 27.0) * Math.Pow(alfa, 3);
  63.                         var bm = 0.9996 * c * (lat - alfa * j2 + beta * j4 - gama * j6);
  64.                         var b = (y - bm) / v;
  65.                         var epsi = ((e2cuadrada * Math.Pow(a, 2)) / 2.0) * Math.Pow((Math.Cos(lat)), 2);
  66.                         var eps = a * (1 - (epsi / 3.0));
  67.                         var nab = (b * (1 - epsi)) + lat;
  68.                         var senoheps = (Math.Exp(eps) - Math.Exp(-eps)) / 2.0;
  69.                         var delt = Math.Atan(senoheps / (Math.Cos(nab)));
  70.                         var tao = Math.Atan(Math.Cos(delt) * Math.Tan(nab));
  71.
  72.                         longitude = (delt / Math.PI) * 180 + s;
  73.                         latitude = (((lat + (1 + e2cuadrada * Math.Pow(Math.Cos(lat), 2) - (3.0 / 2.0) * e2cuadrada * Math.Sin(lat) * Math.Cos(lat) * (tao - lat)) * (tao - lat))) / Math.PI) * 180; // era incorrecto el calculo
  74.
  75.                         Console.WriteLine("Latitud: " + latitude.ToString() + "\nLongitud: " + longitude.ToString());
  76.
  77.                 }
  78.         }
  79. }
Produces the following:
UTM to LatLon test
Enter utmX: 451602.19
Enter utmY: 4519076.99
Enter UTM Zone: 33N
Latitud: 40.8212871342299
Longitud: 14.4260799700565
Press any key to continue...
« Last Edit: December 06, 2014, 08:10:03 AM by irneb »
irneb
Re: C++ to lisp
« Reply #13 on: December 06, 2014, 08:26:39 AM »
Looking through your Lisp code ... this might be the culprit:
  1. ;;var bm = 0.9996 * c * (lat - alfa * j2 + beta * j4 - gama * j6);
  2. (setq bm (* 0.9996 c (- lat (+ (* alfa j2) (* beta j4)) (* gama j6))))   ;;;not shore
  3. ;; Should be something like this
  4. (setq bm (* 0.9996 c (- (+ (- lat (* alpha j2)) (* beta j4)) (* gama j6)))))
pedroantonio124
Re: C++ to lisp
« Reply #14 on: December 08, 2014, 04:40:17 AM »
Hello irneb,
Thanks for your help  :-)
Unfortunately, I still receive the wrong result with the lisp code.
Maybe I can find the mistake if I know the result of every line.
Could you let me the C # run through over again code? Please
With a Console.WriteLine for every line.
PedroAntonio  :evil:
Console.WriteLine ("\n" e2.ToString() )
Console.WriteLine ("\n" e2cuadrada.ToString() )
Console.WriteLine ("\n" c.ToString() )
Console.WriteLine ("\n" x.ToString() )
Console.WriteLine ("\n" y.ToString() )
Console.WriteLine ("\n" s.ToString() )
Console.WriteLine ("\n" lat.ToString() )
Console.WriteLine ("\n" v.ToString() )
        var a = x / v;
Console.WriteLine ("\n" a.ToString() )
Console.WriteLine ("\n" a1.ToString() )
Console.WriteLine ("\n" a2.ToString() )
Console.WriteLine ("\n" j2.ToString() )
Console.WriteLine ("\n" j4.ToString() )
        Console.WriteLine ("\n" j6.ToString() )
Console.WriteLine ("\n" alfa.ToString() )
Console.WriteLine ("\n" beta.ToString() )
Console.WriteLine ("\n" gama.ToString() )
Console.WriteLine ("\n" bm.ToString() )
Console.WriteLine ("\n" b.ToString() )
Console.WriteLine ("\n" epsi.ToString() )
Console.WriteLine ("\n" eps.ToString() )
Console.WriteLine ("\n" nab.ToString() )
Console.WriteLine ("\n" senoheps.ToString() )
Console.WriteLine ("\n" delt.ToString() )
Console.WriteLine  ("\n" tao.ToString() )
Re: C++ to lisp
« Reply #15 on: December 08, 2014, 04:45:38 AM »
pedroantonio124,
Which AutoCAD build are you using ?
pedroantonio124
Re: C++ to lisp
« Reply #16 on: December 08, 2014, 04:54:23 AM »
AutoCad 2014
irneb
Re: C++ to lisp
« Reply #17 on: December 08, 2014, 05:30:16 AM »
Hello irneb,
Rather than a WriteLine per line ... just get hold of a DotNet IDE and debug step through it.
You can get a free IDE, either of these would do:
Re: C++ to lisp
« Reply #18 on: December 08, 2014, 05:36:07 AM »
You want fries with this ?
Code - C#: [Select]
  1. using System;
  2. using System.Collections.Generic;
  3. using System.Globalization;
  4. using System.Linq;
  5. using System.Text;
  6. using System.Threading.Tasks;
  7.
  8. namespace ToLatLon
  9. {
  10.     internal class Program
  11.     {
  12.         private static void Main(string[] args)
  13.         {
  14.             Console.Write("\n UTM to LatLon test.\n From theSwamp\n http://www.theswamp.org/index.php?topic=48330.0" );
  15.             Console.Write("\n\nEnter utmX value : " );
  16.             double utmX = double.Parse(Console.ReadLine());
  17.
  18.             Console.Write("\nEnter utmY value : " );
  19.             double utmY = double.Parse(Console.ReadLine());
  20.
  21.             Console.Write("\nEnterutmZone value : " );
  22.             string utmZone = Console.ReadLine();
  23.
  24.             ToLatLon(utmX, utmY, utmZone);
  25.
  26.             Console.ReadKey();
  27.         }
  28.
  29.         public static void ToLatLon(double utmX, double utmY, string utmZone)
  30.         {
  31.             double latitude = 0;
  32.             double longitude = 0;
  33.
  34.             bool isNorthHemisphere = utmZone.Last() >= 'N';
  35.
  36.             var diflat = -0.00066286966871111111111111111111111111;
  37.             var diflon = -0.0003868060578;
  38.
  39.             var zone = int.Parse(utmZone.Remove(utmZone.Length - 1));
  40.             var c_sa = 6378137.000000;
  41.             var c_sb = 6356752.314245;
  42.
  43.             var e2 = Math.Pow((Math.Pow(c_sa, 2) - Math.Pow(c_sb, 2)), 0.5)/c_sb;
  44.             Console.WriteLine("\ne2:\t " + e2.ToString());
  45.
  47.             Console.WriteLine("\ne2cuadrada:\t " + e2cuadrada.ToString());
  48.
  49.             var c = Math.Pow(c_sa, 2)/c_sb;
  50.             Console.WriteLine("\nc:\t " + c.ToString());
  51.
  52.             var x = utmX - 500000;
  53.             Console.WriteLine("\nx:\t " + x.ToString());
  54.
  55.             var y = isNorthHemisphere ? utmY : utmY - 10000000;
  56.             Console.WriteLine("\ny:\t " + y.ToString());
  57.
  58.             var s = ((zone*6.0) - 183.0);
  59.             Console.WriteLine("\ns:\t " + s.ToString());
  60.
  61.             var lat = y/(6366197.724*0.9996); // Change c_sa for 6366197.724
  62.             Console.WriteLine("\nlat:\t " + lat.ToString());
  63.
  64.             var v = (c/
  65.                      Math.Pow(1 + (e2cuadrada*Math.Pow(Math.Cos(lat), 2)), 0.5))*
  66.                     0.9996;
  67.             Console.WriteLine("\nv:\t " + v.ToString());
  68.
  69.             var a = x/v;
  70.             Console.WriteLine("\na:\t " + a.ToString());
  71.
  72.             var a1 = Math.Sin(2*lat);
  73.             Console.WriteLine("\na1:\t " + a1.ToString());
  74.
  75.             var a2 = a1*Math.Pow((Math.Cos(lat)), 2);
  76.             Console.WriteLine("\na2:\t " + a2.ToString());
  77.
  78.             var j2 = lat + (a1/2.0);
  79.             Console.WriteLine("\nj2:\t " + j2.ToString());
  80.
  81.             var j4 = ((3*j2) + a2)/4.0;
  82.             Console.WriteLine("\nj4:\t" + j4.ToString());
  83.
  84.             var j6 = (5*j4 + a2*Math.Pow((Math.Cos(lat)), 2))/3.0;
  85.             // saque a2 de multiplicar por el coseno de lat y elevar al cuadrado
  86.             Console.WriteLine("\nj6:\t " + j6.ToString());
  87.
  88.             var alfa = (3.0/4.0)*e2cuadrada;
  89.             Console.WriteLine("\nalfa:\t " + alfa.ToString());
  90.
  91.             var beta = (5.0/3.0)*Math.Pow(alfa, 2);
  92.             Console.WriteLine("\nbeta:\t " + beta.ToString());
  93.
  94.             var gama = (35.0/27.0)*Math.Pow(alfa, 3);
  95.             Console.WriteLine("\ngama:\t " + gama.ToString());
  96.
  97.             var bm = 0.9996*c*(lat - alfa*j2 + beta*j4 - gama*j6);
  98.             Console.WriteLine("\nbm:\t " + bm.ToString());
  99.
  100.             var b = (y - bm)/v;
  101.             Console.WriteLine("\nb:\t " + b.ToString());
  102.
  103.             var epsi = ((e2cuadrada*Math.Pow(a, 2))/2.0)*
  104.                        Math.Pow((Math.Cos(lat)), 2);
  105.             Console.WriteLine("\nepsi:\t " + epsi.ToString());
  106.
  107.             var eps = a*(1 - (epsi/3.0));
  108.             Console.WriteLine("\neps:\t " + eps.ToString());
  109.
  110.             var nab = (b*(1 - epsi)) + lat;
  111.             Console.WriteLine("\nnab:\t " + nab.ToString());
  112.
  113.             var senoheps = (Math.Exp(eps) - Math.Exp(-eps))/2.0;
  114.             Console.WriteLine("\nsenoheps:\t " + senoheps.ToString());
  115.
  116.             var delt = Math.Atan(senoheps/(Math.Cos(nab)));
  117.             Console.WriteLine("\ndelt:\t " + delt.ToString());
  118.
  119.             var tao = Math.Atan(Math.Cos(delt)*Math.Tan(nab));
  120.             Console.WriteLine("\ntao:\t " + tao.ToString());
  121.
  122.             longitude = (delt/Math.PI)*180 + s;
  123.             latitude = (((lat +
  124.                           (1 + e2cuadrada*Math.Pow(Math.Cos(lat), 2) -
  125.                            (3.0/2.0)*e2cuadrada*Math.Sin(lat)*Math.Cos(lat)*
  126.                            (tao - lat))*(tao - lat)))/Math.PI)*180;
  127.             // era incorrecto el calculo
  128.
  129.             Console.WriteLine("\nLatitud:\t " + latitude.ToString() +
  130.                 "\nLongitud:\t " + longitude.ToString());
  131.         }
  132.     }
  133. }
  134.
irneb
Re: C++ to lisp
« Reply #19 on: December 08, 2014, 06:05:44 AM »
Damn ... you're much to quick!
Anyhow, if you don't want to install anything new, you could use IDEone: http://ideone.com/5irS8R
pedroantonio124
Re: C++ to lisp
« Reply #20 on: December 08, 2014, 06:06:25 AM »
Thanks  :-D
This was the mistake in the Lisp code
It now works  :lol: :-P ^-^ :laugh: :blank:
Incorrect: (setq eps (* a (1-  (/ epsi 3.0)))))
OK: (setq eps (* a (- 1 (/ epsi 3.0)))))
pedroantonio124
Re: C++ to lisp
« Reply #21 on: December 08, 2014, 10:45:05 AM »
Thanks to irneb and Kerry  :-)
example:
(utm2latlong 451602.19 4519076.99 "33N")
->40.821287°  14.426080°
PedroAntonio  :evil: :-P
(defun utm2latlong (utmX utmY utmZone / latitude longitude isNorthHemisphere diflat diflon zone c_sa
c_sb e2 e2cuadrada c x y s lat v a a1 a2 j2 j4 j6 alfa beta gama bm b
epsi eps nab senoheps delta tao longitude latitude)
(defun tan (x / c)
(/ (sin x) c)
(setq LATLONG nil)
(setq a (/ x v))
(setq nab (+ (* b (- 1 epsi)) lat))
(setq LATLONG (list latitude longitude ))
LATLONG
mailmaverick
Re: C++ to lisp
« Reply #22 on: February 22, 2017, 02:44:37 AM »
example:
(defun tan (x / c)
(/ (sin x) c)
(setq LATLONG nil)
(setq a (/ x v))
LATLONG
Dear Pedro,
Excellent LISP. Works great. Do you have reverse LISP i.e. to convert Lat , Long to UTM Coordinates ?
d2010
Re: C++ to lisp
« Reply #23 on: February 24, 2017, 06:59:03 AM »
You convert  huge math equations to autolisp -R14
You can convert 9999-maths-equations to autolispR14..full automatically.
Please you see details at.
Step1) You downloading the compilator
Step2) You insert  your math  equatiosn into file. ,Vlax as .Zip
Step3) You compile then vlax.
Allea gutes..
http://lisp2arx.3xforum.ro/post/19/1/VirtualC_Lisp/
http://www.puiubrat.3x.ro/adve2011/netilisq.html
  • Custom Title
Re: C++ to lisp
« Reply #24 on: February 24, 2017, 07:13:24 AM »
Damn. Nice visual too. :)
You guys amaze me.
Re: C++ to lisp
« Reply #25 on: February 24, 2017, 08:33:46 AM »
An 809 day delay is also amazing. :-P
But yeah, mad props to KB.
  • Custom Title
Re: C++ to lisp
« Reply #26 on: February 24, 2017, 08:44:53 AM »
LOL
better late than never!
Re: C++ to lisp
« Reply #27 on: February 24, 2017, 09:00:01 AM »
I don't claim to be the record holder but a 1899 delay is a worthy contender.
Bwaaaaaa, lmao ... 5 years later proves useful.  :lmao:
 :-D
  • Custom Title
Re: C++ to lisp
« Reply #28 on: February 24, 2017, 10:26:55 AM »
 :-D
To funny. :)
