Author Topic: How do you get a pickpoint on a line as a 3d point ?  (Read 4742 times)
Peter Laker
« on: February 23, 2008, 12:05:00 AM »
Just started getting into C# & can't work out how to get a 3d point from a pick point on a 3d line.
I have worked out this so far which works ok in 2d but not 3d, in 3d it looks like it returns a point in the DCS (it's got no Z)
Point3d pickPt = entitySelectionResult.PickedPoint;
I have seen some reference made to PointOnLine but can't work out how to use it.
Any help would be appreciated, Thanks...
Re: How do you get a pickpoint on a line as a 3d point ?
« Reply #1 on: February 23, 2008, 12:33:59 AM »
Code - C#: [Select]
  1.
Hello Peter ;
Have a play with something like  this
Code - C#: [Select]
  1. //// CodeHimBelongaKwb ©  Feb 2008
  2.
  3.         [AcRx.CommandMethod("ListIt")]
  4.         static public void ListIt()
  5.         {
  6.             AcEd.Editor ed = AcadApp.DocumentManager.MdiActiveDocument.Editor;
  7.             AcEd.PromptEntityResult resEnt = ed.GetEntity("\nSelect an Object: ");
  8.             if (resEnt.Status != AcEd.PromptStatus.OK)
  9.             {
  10.                 ed.WriteMessage("\nNothing selected");
  11.                 return;
  12.             }
  13.             // Something selected, so ..
  14.             // do come stuff ..
  15.             ed.WriteMessage("\n PromptEntityResult : " + resEnt.ToString());
  16.             ed.WriteMessage("\n PickedPoint : " + resEnt.PickedPoint.ToString());
  17.
  18.             // Get the ObjectId
  19.             AcDb.ObjectId ObjId = (resEnt.ObjectId);
  20.             ed.WriteMessage("\n Object Id : " + resEnt.ObjectId.ToString());
  21.
  22.             // Add Breakpoint here
  23.             Point3d pickPt = resEnt.PickedPoint;
  24.
  25.             // Get the Entity
  26.             AcDb.Entity ent = kdubGetEntity(resEnt.ObjectId);
  27.             ed.WriteMessage("\n Entity : " + ent.ToString() + "\n");
  28.             ent.List();
  29.
  30.             Extents3d extents3D = ent.GeometricExtents;
  31.             ed.WriteMessage("\n extents3D : " + extents3D.ToString());
  32.             ed.WriteMessage("\n extents3D.LLPoint : " + extents3D.MinPoint.ToString());
  33.             ed.WriteMessage("\n extents3D.URPoint : " + extents3D.MaxPoint.ToString());
  34.
  35.             // PROBLEM : how to locate the Entity WCS location ??
  36.
  37.             Matrix3d ecsPossy = ent.Ecs;
  38.             ed.WriteMessage("\n ECS : " + ecsPossy.ToString());
  39.
  40.         }
  41.
  42.         public static Entity kdubGetEntity(AcDb.ObjectId id)
  43.         {
  44.             AcDb.Entity ent;
  45.             AcDb.TransactionManager tm =
  46.                 AcadApp.DocumentManager.MdiActiveDocument.TransactionManager;
  47.
  48.             using (AcDb.Transaction tr = tm.StartTransaction())
  49.             {
  50.                 ent = (AcDb.Entity)tm.GetObject(id, AcDb.OpenMode.ForRead, true);
  51.             }
  52.             return ent;
  53.         }
« Last Edit: August 10, 2023, 02:25:15 AM by kdub_nz »
« Reply #2 on: February 23, 2008, 12:50:44 AM »
Command: list
Select objects: 1 found
Select objects:
                  LINE      Layer: "0"
                            Space: Model space
                   Handle = 7f
              from point, X= 223.7900  Y=   0.0000  Z= 222.1967
                to point, X=1538.5387  Y= 867.8355  Z=-368.4467
Extrusion direction relative to UCS:
                   X=   0.0000  Y=   1.0000  Z=   0.0000
          In Current UCS, Length =1575.3420,  Angle in XY Plane =     33
                  3D Length  =1682.4275,  Angle from XY Plane =    339
                  Delta X =1314.7487, Delta Y =  867.8355, Delta Z =-590.6434
Command: listit
Select an Object: _MID of
((OK,),(2130436152),(881.164319159307,433.917747505122,-73.125000386091))
 PickedPoint : (881.164319159307,433.917747505122,-73.125000386091)
 Object Id : (2130436152)
 Entity : Autodesk.AutoCAD.DatabaseServices.Line
                  LINE      Layer: "0"
                            Space: Model space
                   Handle = 7f
 extents3D :
((223.789977837311,-222.196720773481,0),(1538.5386604813,368.446721545663,867.835495010243))
 extents3D.LLPoint : (223.789977837311,-222.196720773481,0)
 extents3D.URPoint : (1538.5386604813,368.446721545663,867.835495010243)
 ECS : ((1,0,0,0),(0,1,0,0),(0,0,1,0),(0,0,0,1))
and the piccy
« Reply #3 on: February 23, 2008, 01:54:01 AM »
This may help too ..
Add these helpers  to a static class
Code - C#: [Select]
  1.
  2. // CodeHimBelongaKwb ©  Feb 2008
  3.
  4. public static partial class dbExtensions
  5.     {
  6.         public static AcGe.Point3d UcsToWcs(this AcGe.Point3d pt, AcDb.Database db)
  7.         {
  8.             return pt.TransformBy(db.GetUcsMatrix());
  9.         }
  10.         public static bool IsPaperSpaceActive(this AcDb.Database db)
  11.         {
  12.             if (db.TileMode)
  13.             { return false; }
  14.             return (db.PaperSpaceVportId == AcadApp.DocumentManager.MdiActiveDocument.
  15.                 Editor.CurrentViewportObjectId);
  16.         }
  17.         public static AcGe.Matrix3d GetUcsMatrix(this AcDb.Database db)
  18.         {
  19.             AcGe.Point3d ucsorgin = db.Ucsorg;
  20.             AcGe.Vector3d ucsxdir = db.Ucsxdir;
  21.             AcGe.Vector3d ucsydir = db.Ucsydir;
  22.             // re-assign variables if PaperSpace is Active
  23.             if (db.IsPaperSpaceActive())
  24.             {
  25.                 ucsorgin = db.Pucsorg;
  26.                 ucsxdir = db.Pucsxdir;
  27.                 ucsydir = db.Pucsydir;
  28.             }
  29.             // Vector3d newZAxis = ucsxdir.CrossProduct(ucsydir);
  30.             return Matrix3d.AlignCoordinateSystem(
  31.                 AcGe.Point3d.Origin,
  32.                 AcGe.Vector3d.XAxis,
  33.                 AcGe.Vector3d.YAxis,
  34.                 AcGe.Vector3d.ZAxis,
  35.                 ucsorgin,
  36.                 ucsxdir,
  37.                 ucsydir,
  38.                 ucsxdir.CrossProduct(ucsydir)
  39.              );
  40.         }
  41.     }
Amend the code to return the point in WCS as well as UCS
Code - C#: [Select]
  1.
  2.         // // CodeHimBelongaKwb ©  Feb 2008
  5.         {
  6.             AcDb.Database db = AcDb.HostApplicationServices.WorkingDatabase;
  7.             AcEd.Editor ed = AcadApp.DocumentManager.MdiActiveDocument.Editor;
  8.             AcEd.PromptEntityResult resEnt = ed.GetEntity("\nSelect an Object: ");
  9.             if (resEnt.Status != AcEd.PromptStatus.OK)
  10.             {
  11.                 ed.WriteMessage("\nNothing selected");
  12.                 return;
  13.             }
  14.             // Something selected, so ..
  15.             // do come stuff ..
  16.             ed.WriteMessage("\n PromptEntityResult : " + resEnt.ToString());
  17.
  18.             AcGe.Point3d pickPt = resEnt.PickedPoint;
  19.             ed.WriteMessage("\n PickedPoint in UCS : " + pickPt.ToString());
  20.
  21.             AcGe.Point3d WCSPoint = pickPt.UcsToWcs(db);
  22.             ed.WriteMessage("\n Picked Point in WCS : " + WCSPoint.ToString());
  23.
  24.             // Get the ObjectId
  25.             AcDb.ObjectId ObjId = (resEnt.ObjectId);
  26.             ed.WriteMessage("\n Object Id : " + resEnt.ObjectId.ToString());
  27.
  28.             // Get the Entity
  29.             AcDb.Entity ent = kdubGetEntity(resEnt.ObjectId);
  30.             ed.WriteMessage("\n Entity : " + ent.ToString() + "\n");
  31.             ent.List();
  32.
  33.             AcGe.Extents3d extents3D = ent.GeometricExtents;
  34.             ed.WriteMessage("\n extents3D : " + extents3D.ToString());
  35.             ed.WriteMessage("\n extents3D.LLPoint : " + extents3D.MinPoint.ToString());
  36.             ed.WriteMessage("\n extents3D.URPoint : " + extents3D.MaxPoint.ToString());
  37.
  38.             AcGe.Matrix3d ecsPossy = ent.Ecs;
  39.             ed.WriteMessage("\n ECS : " + ecsPossy.ToString());
  40.         }
and the result :-
Command: ListIt
((OK,),(2130436152),(106.529729152112,1.92859694466527E-14,-86.8562848134239))
PickedPoint in UCS : (106.529729152112,1.92859694466527E-14,-86.8562848134239)
Picked Point in WCS : (106.529729152112,86.8562848134239,0)
« Last Edit: August 10, 2023, 02:26:37 AM by kdub_nz »
« Reply #4 on: February 23, 2008, 02:02:02 AM »
And this is the typical header I use ...
may clarify some of the class addresses listed :-)
Code - C#: [Select]
  1. // CodeHimBelongaKwb ©  Feb 2008
  2.
  3. using System;
  4. using System.Collections;
  5. using System.Collections.Generic;
  6. using System.Text;
  7. using System.Data;
  8. using System.Linq;
  9. using System.Windows.Forms;
  10.
  11. // using System.Runtime.InteropServices;
  12.
  13. using Autodesk.AutoCAD.ApplicationServices;
  14. using Autodesk.AutoCAD.DatabaseServices;
  15. using Autodesk.AutoCAD.EditorInput;
  16. using Autodesk.AutoCAD.Geometry;
  17. using Autodesk.AutoCAD.Runtime;
  18. //
  19. using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
  20. using AcAp = Autodesk.AutoCAD.ApplicationServices;
  21. using AcDb = Autodesk.AutoCAD.DatabaseServices;
  22. using AcEd = Autodesk.AutoCAD.EditorInput;
  23. using AcGe = Autodesk.AutoCAD.Geometry;
  24. using AcRx = Autodesk.AutoCAD.Runtime;
  25. //
  26. using AcCm = Autodesk.AutoCAD.Colors;
  27. using AcGi = Autodesk.AutoCAD.GraphicsInterface;
  28. using AcLy = Autodesk.AutoCAD.LayerManager;
  29. using AcPl = Autodesk.AutoCAD.PlottingServices;
  30. using AcUi = Autodesk.AutoCAD.Windows;
  31.
  32. using WinForms = System.Windows.Forms;
« Last Edit: August 10, 2023, 02:31:57 AM by kdub_nz »
Peter Laker
« Reply #5 on: February 23, 2008, 06:10:27 PM »
Awesome reply Kerry thanks.
I see in your samples that you have used mid point snap to select the line, in the testing I have been doing I haven't been using any snaps hence no Z.
I was trying to use this function without having to have the user select any snap modes when selecting the line, just run the command & pick.
Using your Listit function on the test2 drawing attached if I select a point on the line inside the green circle I get the following returned.
You will see on the PromptEntityResult: the Z is 0.
Command: listit
Select an Object:
 PromptEntityResult : ((OK,),(2130326424),(-108.540422813801,1969.286990748,0))
 PickedPoint in UCS : (-108.540422813801,1969.286990748,0)
 Picked Point in WCS : (-108.540422813801,1969.286990748,0)
 Object Id : (2130326424)
                  LINE      Layer: "0"
                            Space: Model space
                   Handle = 1b3
              from point, X= 837.3668  Y= 811.1579  Z=1178.9697
                to point, X=1086.9430  Y=1698.9099  Z= 157.6337
                   X=   0.0000  Y=  -1.0000  Z=   0.0000
          In Current UCS, Length = 922.1669,  Angle in XY Plane =     74
                  3D Length  =1376.0520,  Angle from XY Plane =    312
                  Delta X = 249.5762, Delta Y =  887.7520, Delta Z =-1021.3360
 extents3D :
((837.36683616951,811.157907859753,157.633678487386),(1086.94300072584,1698.9099
0309033,1178.96967277117))
 extents3D.LLPoint : (837.36683616951,811.157907859753,157.633678487386)
 extents3D.URPoint : (1086.94300072584,1698.90990309033,1178.96967277117)
 ECS :
((1,0,0,0),(0,2.22044604925031E-16,-1,0),(0,1,2.22044604925031E-16,0),(0,0,0,1))
I have added a snap mode near to the PickPoint.
//Point3d pickPt = resEnt.PickedPoint;
Point3d pickPt = ed.Snap("NEAR", resEnt.PickedPoint);
Listit using snap near code above.
You will see that the PromptEntityResult: has no Z & the PickPoint in UCS & WCS are now on the line.
This solution works for what I'm doing but I'm just wondering if a snap mode can be used with the first pick point or if there is another solution.
Command: listit
Select an Object:
((OK,),(2130461592),(-104.371741178205,1962.27347647723,0))
 PickedPoint in UCS : (883.703374628186,975.978753399603,989.347500066942)
 Picked Point in WCS : (883.703374628186,975.978753399603,989.347500066942)
 Object Id : (2130461592)
                  LINE      Layer: "0"
                            Space: Model space
                   Handle = 1b3
 extents3D :
 ECS :
Thanks again Kerry your a mountain of knowledge.
« Reply #6 on: February 24, 2008, 05:35:27 AM »
Peter,
I appears that the value held internally in the AcEd.PromptEntityResult IS in the DCS when there is no manual Osnap Override.
With your Test2 Drawing,
Rotate the UCS about X 90 and run the routine again.
Currently in the drawing, The active UCS is world ; so any selection , reported in UCS, will be the same as world.
For instance, before UCS rotation ;
the top of the line marked with a circle is now ;
Command: id
Specify point: _ENDP of  X = 837.3668     Y = 811.1579     Z = 1178.9697
when I rotate the ucs X 90 [ front ]
the top point is ;
Command: id
Specify point: _ENDP of  X = 837.3668     Y = 1178.9697     Z = -811.1579
Run Listit selecting the ' _END' of the same line ;
((OK,),(2130633624),(837.36683616951, 1178.96967277117, -811.157907859751))
 PickedPoint in UCS : (837.36683616951,1178.96967277117,-811.157907859751)
 Picked Point in WCS : (837.36683616951,811.157907859753,1178.96967277117)
Change code to : (similar to your mod but using  "_ENDPOINT" )
{I know _ENDP would hardly ever be used , but it does select at a demonstrable known point}
selecting the same line, at the upper end ;
 PromptEntityResult : ((OK,),(2130633624),(1649.62730512099, 2001.15440070052, 0))
  Interesting bit of a testing exercise  :-)
« Reply #7 on: February 24, 2008, 06:10:11 AM »
This is related :-
http://www.theswamp.org/index.php?topic=21568.0
but I ran out of time ...
« Reply #8 on: February 29, 2008, 10:25:30 PM »
Peter,
This may be handy , using the Library routines from  http://www.theswamp.org/index.php?topic=21568.0
... and the  reciprocal translations of course :-)
            AcGe.Point3d DCSPoint = WCSPoint.TranslateCoordinates(
                     dbExtensions.CoOrds.WCS,
                     dbExtensions.CoOrds.DisplayDCS
            ed.WriteMessage("\n Picked Point translated WCS->DisplayDCS : " + DCSPoint.ToString());
Bryco
« Reply #9 on: March 01, 2008, 12:29:02 PM »
Kerry, I've found it to be in ucs form, although .net may have a different version of Dcs than vba.
DCS
Display coordinate system: The coordinate system where objects are transformed before they are displayed. The origin of the DCS is the point stored in the AutoCAD system variable TARGET, and its Z axis is the viewing direction. In other words, a viewport is always a plan view of its DCS. These coordinates can be used to determine where something will be displayed to the AutoCAD user.
MickD
« Reply #10 on: March 02, 2008, 04:13:41 PM »
If you don't use a snap to pick a point, the z value will always be the value of the pick point projected to current x/y working plane, therefore it will be 0.0. Otherwise the z value could be just 'anywhere', it is logical though to use the x and y values as that is the current work plane - if that makes sense :).
- John Carmack
- J.R.R. Tolkien
Bryco
« Reply #11 on: March 03, 2008, 08:35:30 PM »
Mick that's what it should be, so far my tests don't hold up that way.
Peter Laker
« Reply #12 on: March 03, 2008, 11:39:12 PM »
Peter,
I haven't had time to play with much of this been working at the day job to much.
Thanks for your help Kerry  8-)
« Last Edit: March 03, 2008, 11:47:14 PM by Peter Laker »
Peter Laker
« Reply #13 on: March 03, 2008, 11:41:30 PM »
Yes I aggree Mick, when I was testing this is exactly what was happening  :-)
