Hey all, I don't normally beg code, but this is one that probably wouldn't be to hard for you gurus and a lot of people would be able to make use of. I cant code my way out of a paper bag so its beyond me though.What I would like to do is have a command that lets you click on a section marker that has attributes (detail number and sheet). It would read the sheet attribute and create a hyperlink on the block to pop to that sheet view. It would just be a nice touch for navigating once these things are dwfs for clients. I did a search but didn't find this and as most of my work for clients doesn't use SSM that option isn't available.Any thoughts on how to accomplish this? I can probably cludge something together given a starting point, any advice?
Easier then that, just want to go to the sheet. The person can find the correct detail easy enough with that. So I only need the SHEET attribute out of the block and have that as the target.I can do it manually with the hyperlink command of course, just looking to automate it.
ah sorry, yes, just the layout tab name. I'll get a sample drawing together and get it up when I can.
Lee, just.. WOW, that does all of them in a mass strike, that's amazing.Does exactly what I was after only even better, I thankee.Do you mind if I point people to this thread? I have a feeling a lot of folks would find this very useful.
Ah sorry, you name showed there in the code, I was rather blown away. Kruuger, you indeed rock, but most of the people here tend to rock.
