Author Topic: Publishing PDF not to include the layout name  (Read 1458 times)
reyas1123
« on: June 27, 2016, 03:50:33 AM »
Is there a way to publish drawings to PDF not to include the layout name.
Peter2
Re: Publishing PDF not to include the layout name
« Reply #1 on: June 27, 2016, 04:25:53 AM »
If you use a PDF-printdriver instead of DWGtoPDF, there are some features of name-handling and modification, depending on the features offered by the driver (For example PDF-XChange has a JS-based name processing).
Peter
BricsCAD V23
ChrisCarlson
« Reply #2 on: June 27, 2016, 07:57:11 AM »
Under the settings of PDF Publish, there should be "Create Bookmarks", turn this off and the layout name should disappear from the PDF.
David Bethel
« Reply #3 on: June 27, 2016, 03:48:42 PM »
If you have Distiller ( or equal ), you can plot to a postscript device in a script or lsp environment and then combine the outputs file via .ps cover.  This gives you most flexibility that I've ever found.  It's been around forever but seldom do I hear of anyone using much anymore
-David
R12 Dos - A2K
reyas1123
« Reply #4 on: June 28, 2016, 03:12:39 AM »
Thanks for the replies
I did chris advise but still showing the pdf layout name, @peter i have downloaded the pdf exchange but i could not found the setting that you specified.
thanks friends for the kind effort,
Peter2
« Reply #5 on: June 28, 2016, 11:02:10 AM »
... @peter i have downloaded the pdf exchange but i could not found the setting that you specified...
You have to search for "titrules.js" in help file, support forum (there are some examples) and your PDF installation.
Peter
BricsCAD V23
