Author Topic: How to fix icon  (Read 2935 times)
Adesu
How to fix icon
« on: April 03, 2010, 12:34:04 AM »
I create icon for my special drawing, if I reopen that Autocad feature of icon go back to blank, or look attach
HasanCAD
Re: How to fix icon
« Reply #1 on: April 04, 2010, 06:20:01 PM »
I am facing the same ploblem
rkmcswain
Re: How to fix icon
« Reply #2 on: April 05, 2010, 08:35:42 AM »
If you are saving these as .BMP files, make sure to save them in the path specified in OPTIONS (Files tab>Customization Files>Custom Icon Location)
Adesu
Re: How to fix icon
« Reply #3 on: April 05, 2010, 08:09:10 PM »
Thanks rkmcswain for your respon, but I still use Autocad 2005 in options dialog box there is not "Files tab>Customization Files>Custom Icon Location", then how and where I put that icon.
Re: How to fix icon
« Reply #4 on: April 05, 2010, 09:55:10 PM »
Are the icons in the same location as the MNU, MNS, MNR files ( or .CUI if applicable) ?
rkmcswain
Re: How to fix icon
« Reply #5 on: April 06, 2010, 08:47:01 AM »
Then the .bmp files just need to be in any directory that is included in the support file search path.
Re: How to fix icon
« Reply #6 on: April 06, 2010, 09:24:26 AM »
I think I would try deleting the MNR file & restart Autocad.
Adesu
Re: How to fix icon
« Reply #7 on: April 06, 2010, 09:04:32 PM »
Yes that right.
Adesu
Re: How to fix icon
« Reply #8 on: April 06, 2010, 09:16:34 PM »
Hi CAB....... :lol:
you just solve my problem......thanks very much for your help.
I very glad this problem was solved.
Re: How to fix icon
« Reply #9 on: April 06, 2010, 09:22:17 PM »
Glad it worked for you. I was pulling my hair out, what I have left that is,  until I found the solution for me.
Lots of trial & error.  :-(
rkmcswain
Re: How to fix icon
« Reply #10 on: April 07, 2010, 11:07:13 AM »
Good call CAB!
I've had to do that before also, just didn't think of it until you mentioned it.
