(defun c:testdcl (/ nam$ nam id loop);;; lisp for checking dialogboxes at the beginning of their design (setq nam$ (getfiled "Select a DCL file" "" "dcl" 0)) (setq nam (identify nam$)))(defun identify (nam$ / file x dd dd$) (setq file (open nam$ "r") dd$ nil dd nil x 0 ) (while (setq dd (read-line file)) (if (wcmatch dd "*: dialog {") (progn (setq dd$ (substr dd 1 (- (strlen dd) 11))) (if (wcmatch dd$ " *") (setq dd$ (substr dd$ 2 (strlen dd$))) ;; added for eliminating blank ) (rundcl nam$ dd$) ) ) ) (close file) dd$)(defun rundcl (nam$ nam) (setq id (load_dialog nam$)) (if (not (new_dialog nam id)) (exit) ) (action_tile "cancel" "(done_dialog 0)");;; cancel button dialog.. normally in all DCLs (action_tile "accept" "(done_dialog 0)");;; accept button dialog.. normally in all DCLs (setq loop (start_dialog)))
Do I understand you that VLIDE have a preview-methode for DCL-files.
(defun c:TEST ( / dcl_id fn fname) (vl-load-com) (create_dialog) (setq dcl_id (load_dialog fname)) (if (not (new_dialog "VolymCalculate" dcl_id)) (exit ) ) (set_tile "Text1" "Enter length [m]") (mode_tile "Text1" 2) (action_tile "Text1" "(setq Text1 $value)") (set_tile "Text2" "Enter width [m]") (mode_tile "Text2" 2) (action_tile "Text2" "(setq Text2 $value)") (set_tile "Text3" "Enter heiht [m]") (mode_tile "Text3" 2) (action_tile "Text3" "(setq Text3 $value)") (start_dialog) (unload_dialog dcl_id) (alert (strcat "Volum is " " m" (chr 179))) (vl-file-delete fname) (princ) )-------------------(defun create_dialog () (setq fname (vl-filename-mktemp "dcl.dcl")) (setq fn (open fname "w")) (write-line "VolymCalculate : dialog { label = \"Calculate volym\"; spacer; : row { fixed_width = true; : column { width = 17.5; spacer; : text { key = \"Text1\"; } } : edit_box { edit_width = 6.5; key = \"Edit1\"; } } : row { fixed_width = true; : column { width = 17.5; spacer; : text { key = \"Text2\"; } } : edit_box { edit_width = 6.5; key = \"Edit2\"; } } : row { fixed_width = true; : column { width = 17.5; spacer; : text { key = \"Text3\"; } } : edit_box { edit_width = 6.5; key = \"Edit3\"; } } spacer; : row { : column { : ok_button { width = 11; alignment = right; } } : column { : cancel_button { width = 11; alignment = left; } } }}" fn) (close fn) (princ) )
Thanks Lee! I have done my first try with DCL and have now simple question, I type in values in 3 textboxes but where can I request them to get my result ?Code: [Select](defun c:TEST ( / dcl_id fn fname) (vl-load-com) (create_dialog) (setq dcl_id (load_dialog fname)) (if (not (new_dialog "VolymCalculate" dcl_id)) (exit ) ) (set_tile "Text1" "Enter length [m]") (mode_tile "Text1" 2) (action_tile "Text1" "(setq Text1 $value)") (set_tile "Text2" "Enter width [m]") (mode_tile "Text2" 2) (action_tile "Text2" "(setq Text2 $value)") (set_tile "Text3" "Enter heiht [m]") (mode_tile "Text3" 2) (action_tile "Text3" "(setq Text3 $value)") (start_dialog) (unload_dialog dcl_id) (alert (strcat "Volum is " " m" (chr 179))) (vl-file-delete fname) (princ) )-------------------(defun create_dialog () (setq fname (vl-filename-mktemp "dcl.dcl")) (setq fn (open fname "w")) (write-line "VolymCalculate : dialog { label = \"Calculate volym\"; spacer; : row { fixed_width = true; : column { width = 17.5; spacer; : text { key = \"Text1\"; } } : edit_box { edit_width = 6.5; key = \"Edit1\"; } } : row { fixed_width = true; : column { width = 17.5; spacer; : text { key = \"Text2\"; } } : edit_box { edit_width = 6.5; key = \"Edit2\"; } } : row { fixed_width = true; : column { width = 17.5; spacer; : text { key = \"Text3\"; } } : edit_box { edit_width = 6.5; key = \"Edit3\"; } } spacer; : row { : column { : ok_button { width = 11; alignment = right; } } : column { : cancel_button { width = 11; alignment = left; } } }}" fn) (close fn) (princ) )
1. (action_tile "accept" "(if (CheckVal) (done_dialog))")
(defun (CheckVal) ()- get all tiles value with (get_tile "TextX")- if one of them is empty display alert or add errtile (error tile) under ok_cancel button- convert all text values to real- CheckVal should return T or nil)
(defun c:test ( / create_dialog dcl_id run_dcl);; keep 'fname' as global(defun create_dialog () (setq fb (vl-filename-base (getvar "dwgname"))) (setq fname (strcat (getvar "dwgprefix") fb ".dcl"));; better to create dcl in current folder for debug ! ;;(setq fname (vl-filename-mktemp "dcl.dcl")) (setq fn (open fname "w")) (write-line "//dcl_settings : default_dcl_settings { audit_level = 3; } //Remember to strip out the dcl_settings line before shipping DCL files to users. VolymCalculate : dialog { label = \"Calculate volym\"; spacer; : row { fixed_width = true; : column { width = 17.5; : text { width = 10; key = \"Text1\"; } } : edit_box { edit_width = 6.5; key = \"leng\"; } } : row { fixed_width = true; : column { width = 17.5; : text { width = 10; key = \"Text2\"; } } : edit_box { edit_width = 6.5; key = \"wid\"; } } : row { fixed_width = true; : column { width = 17.5; : text { width = 10; key = \"Text3\"; } } : edit_box { edit_width = 6.5; key = \"hgt\"; } } spacer; : row { : column { : ok_button { width = 11; alignment = right; } } : column { : cancel_button { width = 11; alignment = left; } } }}" fn) (close fn) (princ) ) (defun run_dcl (fname / hgt leng result wid) (if (<= (setq dcl_id (load_dialog fname)) 0) (alert "Error loading DCL file.") )(if (not (new_dialog "VolymCalculate" dcl_id)) (alert "Error loading dialog.")) (set_tile "Text1" "Enter length [m]") (set_tile "Text2" "Enter width [m]") (action_tile "leng" "(setq leng $value)")(action_tile "wid" "(setq wid $value)") (set_tile "Text3" "Enter heiht [m]") (action_tile "hgt" "(setq hgt $value)") (action_tile "OK" "(done_dialog 1)") (action_tile "CANCEL" "(done_dialog 0)") (setq result (start_dialog)) (unload_dialog dcl_id) (if (= result 1) (if (and leng wid hgt) (setq data(list leng wid hgt)) (setq data nil) ) ) data );; main part ;; (create_dialog) (setq lst (run_dcl fname)) (setq lst (mapcar 'atof lst))(alert (strcat "\nVolume is " (rtos (* (car lst) (cadr lst) (caddr lst)) 2 3) " m" (chr 179)))(vl-file-delete fname) (princ) );; ;;
(defun c:test ( / create_dialog data dcl_id run_dcl);; keep 'fname' as global(defun create_dialog () (setq fb (vl-filename-base (getvar "dwgname"))) (setq fname (strcat (getvar "dwgprefix") fb ".dcl"));; better to create dcl in current folder for debug ! ;;(setq fname (vl-filename-mktemp "dcl.dcl")) (setq fn (open fname "w")) (write-line "//dcl_settings : default_dcl_settings { audit_level = 3; } //Remember to strip out the dcl_settings line before shipping DCL files to users. VolymCalculate : dialog { label = \"Calculate volym\"; spacer; : row { fixed_width = true; : column { width = 17.5; : text { width = 10; key = \"Text1\"; } } : edit_box { edit_width = 6.5; key = \"leng\"; } } : row { fixed_width = true; : column { width = 17.5; : text { width = 10; key = \"Text2\"; } } : edit_box { edit_width = 6.5; key = \"wid\"; } } : row { fixed_width = true; : column { width = 17.5; : text { width = 10; key = \"Text3\"; } } : edit_box { edit_width = 6.5; key = \"hgt\"; } } spacer; : row { : column { : ok_button { width = 11; alignment = right; } } : column { : cancel_button { width = 11; alignment = left; } } }}" fn) (close fn) (princ) ) (defun run_dcl (fname / hgt leng result wid) (if (<= (setq dcl_id (load_dialog fname)) 0) (alert "Error loading DCL file.") )(if (not (new_dialog "VolymCalculate" dcl_id)) (alert "Error loading dialog."))(set_tile "Text1" "Enter length [m]")(set_tile "Text2" "Enter width [m]")(set_tile "Text3" "Enter heiht [m]") (mode_tile "leng" 2) (action_tile "leng" "(setq leng $value)(if (/= $reason 2)(mode_tile \"wid\" 2))") (action_tile "wid" "(setq wid $value)(if (/= $reason 2)(mode_tile \"hgt\" 2))") (action_tile "hgt" "(setq hgt $value)(if (/= $reason 2)(mode_tile \"OK\" 2))") (action_tile "OK" "(done_dialog 1)") (action_tile "CANCEL" "(done_dialog 0)") (setq result (start_dialog)) (unload_dialog dcl_id) (if (= result 1) (if (and leng wid hgt) (setq data (list leng wid hgt)) (setq data nil) ) ) data );; main part ;; (create_dialog) (setq lst (run_dcl fname)) (setq lst (mapcar 'atof lst))(alert (strcat "\nVolume is " (rtos (* (car lst) (cadr lst) (caddr lst)) 2 3) " m" (chr 179)))(vl-file-delete fname) (princ) );; ;;
