Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Change the permission of a Registry Key
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Change the permission of a Registry Key (Read 1890 times)
rajat_mallick
Guest
on:
March 25, 2006, 10:55:51 AM »
Hi !
I want to change the permission (Full control / Read / Special permissions) of a registry key in "HKEY_LOCAL_MACHINE\SOFTWARE\..." by using Visual LISP. But how ??
Any help would be greatly appreciated.
Logged
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
Re: Change the permission of a Registry Key
Reply #1 on:
March 25, 2006, 04:27:51 PM »
If you change it manually with regedit.exe, what values do you change/add ?
Logged
rajat_mallick
Guest
Reply #2 on:
March 25, 2006, 11:13:48 PM »
Normally, in the restricted / Limited type user account, you cannot change a registry key's value which is located in "HKEY_LOCAL_MACHINE\SOFTWARE\...".
To do this, you have to change the permission of that key manually from the administrative type user account.
in the registry editor, Select a key and right click -> "permissions..." -> "select group or user name" and then allow permissions like Full control, Read or special permissions (in windows XP os).
But I want to do this by using Visual Lisp.
I have found some help on msdn but couldn't able to incorporate in Visual Lisp.
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/cpref/html/frlrfsystemsecuritypermissionsregistrypermissionaccessclasstopic.asp
-Rajat
Last Edit: March 26, 2006, 03:46:49 AM by rajat_mallick
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
