Author Topic: Putting two Lisps together into one  (Read 1619 times)
MSTG007
« on: October 06, 2014, 10:39:58 AM »
I am trying to place two lisps into one and I am having no luck. I even thought about making a lisp that activates the 1st lisp then the second. Again, my head is not working. Could you guys guide me please?
Thanks!
(defun c:blkpick ( / loop e bl ss sss s i ent atts attt atttl layn )
(vla-put-Name
  (vla-item
    (vla-get-Blocks
      (vla-get-ActiveDocument
        (vlax-get-acad-object)
  "REVS") ;;;<-- old block name
  "REV") ;;;< -- new block name
  (setq loop t)
  (while loop
    (while (not (eq (cdr (assoc 0 (entget (setq e (car (entsel "\nPick block to put into it's layer : ")))))) "INSERT"))
      (prompt "\nPicked entity doesn't belong to INSERT reference... Try picking again...")
    (setq bl (cdr (assoc 2 (entget e))))
    (if (eq (vla-get-isxref (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) bl)) :vlax-true)
      (prompt "\nSpecified name of block belongs to attached xref in active document... Try again with different name...")
      (setq loop nil)
  (if bl
      (setq ss (ssget "_X" '((0 . "INSERT"))))
      (setq sss (ssadd))
        (setq ent (ssname ss (setq i (1- i))))
        (if (eq (cdr (assoc 2 (entget ent))) bl)
          (ssadd ent sss)
      (setq s (ssadd))
      (repeat (setq i (sslength sss))
        (setq ent (ssname sss (setq i (1- i))))
        (if (not (eq (logand 4 (cdr (assoc 70 (tblsearch "LAYER" (cdr (assoc 8 (entget ent))))))) 4))
          (ssadd ent s)
      (if s
        (repeat (setq i (sslength s))
          (setq ent (ssname s (setq i (1- i))))
          (if (eq 1 (cdr (assoc 66 (entget ent))))
              (setq atts (vlax-invoke (vlax-ename->vla-object ent) 'getattributes))
              (foreach att atts
                (setq attt (vla-get-textstring att))
                (setq atttl (cons attt atttl))
              (setq atttl (reverse atttl))
              (setq layn (if (eq (substr bl 1 1) "*") (strcat "" (substr bl 2) "") (strcat bl "")))
              (foreach attt atttl
                (setq layn (strcat layn "" attt))
              (if (not (tblsearch "LAYER" layn))
                (command "_.-LAYER" "_M" layn "")
              (entupd (cdr (assoc -1 (entmod (subst (cons 8 layn) (assoc 8 (entget ent)) (entget ent))))))
              (setq layn nil atttl nil)
              (setq layn (if (eq (substr bl 1 1) "*") (strcat "" (substr bl 2)) bl))
              (setq layn nil)
and the second.
; File Name: FIXBLOCK.LSP
; Description: Puts all of a blocks sub-entities on layer 0 with color and
; linetype set to BYBLOCK. The block, itself, will remain on
; its' original layer.
(defun d_FixBlock (/ eBlockSel ; Block selection
lInsertData ; Entity data
sBlockName ; Block name
lBlockData ; Entity data
eSubEntity ; Sub-entity name
lSubData ; Sub-entity data
iCount ; Counter
;; Redefine error handler
(setq
d_#error *error*
*error* d_FB_Error
) ;_ end setq
;; Set up environment
(setq #SYSVARS (#SaveSysVars (list "cmdecho")))
(setvar "cmdecho" 0)
(command "._undo" "_group")
;; Get block from user and make sure it's an INSERT type
(if (setq eBlockSel (entsel "\nSelect block to change :"))
(if (setq lInsertData (entget (car eBlockSel)))
(if (= (cdr (assoc 0 lInsertData)) "INSERT")
(setq sBlockName (cdr (assoc 2 lInsertData)))
(alert "Entity selected is not a block!")
(exit)
) ;_ end progn
) ;_ end if
(alert "Invalid Block Selection!")
(exit)
) ;_ end progn
) ;_ end if
;; Get block info from the block table
(setq
lBlockData (tblsearch "BLOCK" sBlockName)
eSubEntity (cdr (assoc -2 lBlockData))
) ;_ end setq
;; Make sure block is not an Xref
(if (not (assoc 1 lBlockData))
(princ "\nProcessing block: ")
(princ sBlockName)
(princ "\nUpdating blocks sub-entities. . .")
;; Parse through all of the blocks sub-entities
(while eSubEntity
(princ " .")
(setq lSubData (entget eSubEntity))
;; Update layer property
(if (assoc 8 lSubData)
(setq lSubData
(subst
(cons 8 "0")
(assoc 8 lSubData)
lSubData
) ;_ end subst
) ;_ end setq
(entmod lSubData)
) ;_ end progn
) ;_ end if
;; Update the linetype property
(if (assoc 6 lSubData)
(setq lSubData
(subst
(cons 6 "BYBLOCK")
(assoc 6 lSubData)
lSubData
) ;_ end subst
) ;_ end setq
(entmod lSubData)
) ;_ end progn
(entmod (append lSubData (list (cons 6 "BYBLOCK"))))
) ;_ end if
;; Update the color property
(if (assoc 62 lSubData)
(setq lSubData
(subst
(cons 62 0)
(assoc 62 lSubData)
lSubData
) ;_ end subst
) ;_ end setq
(entmod lSubData)
) ;_ end progn
(entmod (append lSubData (list (cons 62 0))))
) ;_ end if
(setq eSubEntity (entnext eSubEntity))
; get next sub entity
) ; end while
;; Update attributes
(idc_FB_UpdAttribs)
) ; end progn
(alert "XREF selected. Not updated!")
) ; end if
) ; end progn
(alert "Nothing selected.")
) ; end if
;;; Pop error stack and reset environment
(idc_RestoreSysVars)
(princ "\nDone!")
(setq *error* d_#error)
) ; end defun
; Function to update block attributes
(defun idc_FB_UpdAttribs ()
;; Update any attribute definitions
(setq iCount 0)
(princ "\nUpdating attributes. . .")
(if (setq ssInserts (ssget "x"
(list (cons 0 "INSERT")
(cons 66 1)
(cons 2 sBlockName)
) ;_ end list
) ;_ end ssget
) ;_ end setq
(repeat (sslength ssInserts)
(setq eBlockName (ssname ssInserts iCount))
(if (setq eSubEntity (entnext eBlockName))
(setq
eSubType (cdr (assoc 0 lSubData))
) ;_ end setq
) ;_ end if
(while (or (= eSubType "ATTRIB") (= eSubType "SEQEND"))
(setq lSubData
(subst
(cons 8 "0")
(assoc 8 lSubData)
lSubData
) ;_ end subst
) ;_ end setq
(entmod lSubData)
) ;_ end progn
) ;_ end if
(setq lSubData
(subst
(cons 6 "BYBLOCK")
(assoc 6 lSubData)
lSubData
) ;_ end subst
) ;_ end setq
(entmod lSubData)
) ;_ end progn
) ;_ end if
(setq lSubData
(subst
(cons 62 0)
(assoc 62 lSubData)
lSubData
) ;_ end subst
) ;_ end setq
(entmod lSubData)
) ;_ end progn
) ;_ end if
(if (setq eSubEntity (entnext eSubEntity))
(setq
) ;_ end setq
(setq eSubType nil)
) ;_ end if
) ; end while
(setq iCount (1+ iCount))
) ; end repeat
) ; end if
(command "regen")
) ; end defun
; Function to save a list of system variables
(defun #SaveSysVars (lVarList / sSystemVar)
(mapcar
'(lambda (sSystemVar)
(setq lSystemVars
(append lSystemVars
(list (list sSystemVar (getvar sSystemVar)))
) ;_ end append
) ;_ end setq
) ;_ end lambda
lVarList
) ;_ end mapcar
lSystemVars
) ;_ end defun
; Function to restore a list of system variables
(defun idc_RestoreSysVars ()
(mapcar
(setvar (car sSystemVar) (cadr sSystemVar))
) ;_ end lambda
#SYSVARS
) ;_ end mapcar
) ;_ end defun
; Error Handler
(defun d_FB_Error (msg)
(princ "\nError occurred in the Fix Block routine...")
(princ "\nError: ")
(princ msg)
(if *error*
(*error* msg)
) ;_ end if
(command)
(if (/= msg "quit / exit abort")
(command "._undo" "_end")
(command "._u")
) ;_ end progn
) ;_ end if
) ;_ end defun
(defun C:FB () (d_FixBlock))
Civil3D 2020
ChrisCarlson
Re: Putting two Lisps together into one
« Reply #1 on: October 06, 2014, 11:40:54 AM »
What are you trying to do ? Like the overall jist of what the lisp will be doing?
MSTG007
« Reply #2 on: October 06, 2014, 12:13:56 PM »
Stems of another topic I had someone help me with. I have a block that is hard coded on a layer "ABC", so is the attribute text is on that layer. The second lisp makes the selected block on layer "0" with bylayer color etc. Then the first lisp moves the attribute block to the layer that the attribute names.
Civil3D 2020
