Yes....that's correct. The letter is a single polyline2d;
... you know how normally when you offset - e.g. you are doing the letter "C", it would appear as if there were 2 rows in it because the offset is goes inside the curves of an enclosed poly. (see new pic)...
well, in this paticular senerio, i need it to appear as if there was just one row - just like pic one of first attachment I sent you..with a single row of leds running through the exact center points inside the poly letter.
when i did the code for the 2 rows, I offset the poly and then moved along the curves and using GetPointAtdist method to place the led blocks along this new curve. I'd like to do something similar w/ the one row. I offset and from this offset poly i am trying to find where to place the leds.
i've been struggling struggling...haven't had to much autocad .net experience and this stuff is hard hard hard.
anyway, I appreciate any ideas you may have. thanks for your time too. let me know if you have more questions.
Thanks again,
Proctor
