Author Topic: File size increases for no apparent reason  (Read 6333 times)
Greg B
  • Tell me a Joke!
Re: File size increases for no apparent reason
« Reply #15 on: April 10, 2014, 10:04:27 AM »
Have you tried opening the bloated file and doing a Saveas as a new file name?
I remember something like this happening in the past when I used to CAD with AutoCAD but that was many many versions ago.
Matt__W
  • I like my water diluted.
« Reply #16 on: April 10, 2014, 10:08:23 AM »
The AECTOACAD command will scrub the drawing clean of any AEC info (and 3D info) making it a strictly 2D drawing.
Autodesk Expert Elite
Nardino
« Reply #17 on: April 10, 2014, 11:11:11 AM »
I have tried to resave the file and also the command AECTOACAD but still the same results. There must be ghosts in these files.
« Reply #18 on: April 10, 2014, 11:20:08 AM »
I already explained.
Edit: As I recall the bloated deg had approx a half million bogus regapps.
« Last Edit: April 10, 2014, 11:28:41 AM by MP »
Nardino
« Reply #19 on: April 10, 2014, 11:35:56 AM »
How do I prevent these reg apps to attach to the files?
Nardino
« Reply #21 on: April 10, 2014, 12:49:21 PM »
thank you, i will give this a try
« Reply #22 on: April 10, 2014, 01:00:49 PM »
You don't need anything but to wblock the drawings out using the * option when prompted for <define new drawing>.
Nardino
« Reply #23 on: April 10, 2014, 01:09:29 PM »
thanks again to you and everybody. you all have been a great help.  :-D
« Reply #24 on: April 10, 2014, 01:21:34 PM »
You're most welcome; thanks for the thanks.
tmullins
« Reply #25 on: May 19, 2014, 11:27:59 AM »
If this hasn't been resolved already...
Did the files originate from MicroStation somewhere along the line? We have seen files bloat to 8-10MB with very little in the file and running this fix helped whittle them down to 1MB:
http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autocad-C2-AE-dgn-hotfix.html
HasanCAD
« Reply #26 on: May 26, 2014, 12:36:39 AM »
this is a good tool to clean the infected files
http://bit.ly/1r69Hrp
Nardino
« Reply #27 on: May 28, 2014, 05:31:04 PM »
Thanks, i just downloaded this purge routine and it works very good
DIW_CADtech
  • Push limits, embrace success, & discard failure.
« Reply #28 on: May 30, 2014, 02:18:53 PM »
Two things I do in that situation.. first Purge RegApps
_-purge
R
etc........
2nd
If I have access to autocad 2014 I open with that, and then use
_-exporttoautocad
set the format to 2010
Bind set to "not bind"
Suffex to "2010"
then ent ent ent to save.
it will then save yourfile.dwg to the file yourfile2010.dwg  and it will include the layout as well as model space.
this has the effect of removing any types of items like ARX objects that can cause files to bloat...
If you can give that a shot. and report back that would be awesome.
I am very  trainable....   (forgive my spelling)
