Author Topic: Animated Block Hover  (Read 6347 times)
Jeff H
« on: October 26, 2010, 12:33:56 AM »
Most of this or about all of it is hard-coded but this might inspire a idea for someone.
This will let you hover over a blockrefrence and after 0.25 seconds draw bounding box around all the block references then add 4 circles and remove 4 circles at each corner at 0.25 second intervals.
While the temporary graphics are adding and removing you can keep working.
Here is a link to video Video Link
using System;
using AcadGi =  Autodesk.AutoCAD.GraphicsInterface;
using Autodesk.AutoCAD.Colors;
using System.Collections;
[assembly: CommandClass(typeof(AnimatedBlockHover.BlockHover))]
namespace AnimatedBlockHover
    public class BlockHover
        public static TempGraphics tgStatic = null;
        public static System.Windows.Forms.Control blockHoverCtrl;
       public BlockHover()
            // Create New Windows Control
            blockHoverCtrl = new System.Windows.Forms.Control();
            blockHoverCtrl.CreateControl();
       void SeperateThreadProcess()
            ThreadsDelegate threadDelegate = new ThreadsDelegate(MainThreadProcess);
            TempGraphics tempG = new TempGraphics();
            tempG = tgStatic;
            tempG.drawAction = 0;
            if (blockHoverCtrl.InvokeRequired)
                blockHoverCtrl.Invoke(threadDelegate, tempG);
            else
                MainThreadProcess(tempG);
            System.Threading.Thread.Sleep(250);
            tempG.drawAction = 1;
            else
            tempG.drawAction = 2;
            else
            tempG.drawAction = 3;
            else
            tempG.drawAction = 4;
            else
            tempG.drawAction = -1;
            else
            tempG.drawAction = -2;
            else
            tempG.drawAction = -3;
            else
            tempG.drawAction = -4;
            else
            tempG.drawAction = 250;
            else
        delegate void ThreadsDelegate(object obj);
        void MainThreadProcess(object obj)
            TempGraphics tempG = (TempGraphics)obj;
            if (tempG.drawAction == 0)
                foreach (Polyline pLine in tempG.plList)
                    IntegerCollection coll = new IntegerCollection();
                    AcadGi.TransientManager.CurrentTransientManager.AddTransient(pLine, AcadGi.TransientDrawingMode.DirectShortTerm, 128, coll);
            else if (tempG.drawAction == 1)
                foreach (Circle cir in tempG.circleList1)
                    AcadGi.TransientManager.CurrentTransientManager.AddTransient(cir, AcadGi.TransientDrawingMode.DirectShortTerm, 128, coll);
            else if (tempG.drawAction == 2)
                foreach (Circle cir in tempG.circleList2)
            else if (tempG.drawAction == 3)
                foreach (Circle cir in tempG.circleList3)
            else if (tempG.drawAction == 4)
                foreach (Circle cir in tempG.circleList4)
            else if (tempG.drawAction == -1)
                    AcadGi.TransientManager.CurrentTransientManager.EraseTransient(cir, coll);
                    cir.Dispose();
            else if (tempG.drawAction == -2)
                    cir.Dispose();
            else if (tempG.drawAction == -3)
                    cir.Dispose();
            else if (tempG.drawAction == -4)
                    cir.Dispose();
            else
                    AcadGi.TransientManager.CurrentTransientManager.EraseTransient(pLine, coll);
                    pLine.Dispose();
                tempG.circleList1.Clear();
                tempG.circleList1 = null;
                tempG.circleList2.Clear();
                tempG.circleList2 = null;
                tempG.circleList3.Clear();
                tempG.circleList3 = null;
                tempG.circleList4.Clear();
                tempG.circleList4 = null;
                tempG.plList.Clear();
                tempG.plList = null;
            Application.UpdateScreen();
        [CommandMethod("HighlighBlockReferences")]
        public void HighlighBlockReferences()
            Application.DocumentManager.MdiActiveDocument.Editor.PointMonitor += new PointMonitorEventHandler(HoverHandler);
        private void HoverHandler(object sender, PointMonitorEventArgs e)
            Database db = doc.Database;
            FullSubentityPath[] fsps = e.Context.GetPickedEntities();
            if (fsps.Length > 0)
                FullSubentityPath fsp = fsps[0];
                    try
                        Entity ent = (Entity)tr.GetObject(fsp.GetObjectIds()[0], OpenMode.ForRead);
                        if (ent is BlockReference)
                                BlockReference bref = ent.Id.GetObject(OpenMode.ForRead) as BlockReference;
                                BlockTableRecord btr = bref.BlockTableRecord.GetObject(OpenMode.ForRead) as BlockTableRecord;
                                ObjectIdCollection brefIds = btr.GetBlockReferenceIds(true, false);
                                TempGraphics tg = new TempGraphics();
                                foreach (ObjectId objId in brefIds)
                                    Entity ents = objId.GetObject(OpenMode.ForRead) as Entity;
                                    Point3d min = ents.GeometricExtents.MinPoint;
                                    Point3d max = ents.GeometricExtents.MaxPoint;
                                    Polyline pl = new Polyline();
                                    pl.SetDatabaseDefaults();
                                    Point2d p1 = new Point2d(min.X, min.Y);
                                    Point2d p2 = new Point2d(min.X, max.Y);
                                    Point2d p3 = new Point2d(max.X, max.Y);
                                    Point2d p4 = new Point2d(max.X, min.Y);
                                    pl.AddVertexAt(0, p1, 0, 0, 0);
                                    pl.AddVertexAt(1, p2, 0, 0, 0);
                                    pl.AddVertexAt(2, p3, 0, 0, 0);
                                    pl.AddVertexAt(3, p4, 0, 0, 0);
                                    pl.Color = Color.FromColorIndex(ColorMethod.ByAci, 2);
                                    pl.Closed = true;
                                    tg.plList.Add(pl);
                                    double radius = (max.Y - min.Y) / 6;
                                    Circle cir1 = new Circle(new Point3d(p1.X, p1.Y, 0), Vector3d.ZAxis, radius);
                                    Circle cir2 = new Circle(new Point3d(p2.X, p2.Y, 0), Vector3d.ZAxis, radius);
                                    Circle cir3 = new Circle(new Point3d(p3.X, p3.Y, 0), Vector3d.ZAxis, radius);
                                    Circle cir4 = new Circle(new Point3d(p4.X, p4.Y, 0), Vector3d.ZAxis, radius);
                                    tg.circleList1.Add(cir1);
                                    tg.circleList2.Add(cir2);
                                    tg.circleList3.Add(cir3);
                                    tg.circleList4.Add(cir4);
                                tgStatic = tg;
                                System.Threading.Thread thread = new System.Threading.Thread(new System.Threading.ThreadStart(SeperateThreadProcess));
                                thread.Start();
                    catch
                        tr.Dispose();
                    tr.Commit();
    public class TempGraphics
        public  List<Circle> circleList1 = new List<Circle>();
        public  List<Circle> circleList2 = new List<Circle>();
        public  List<Circle> circleList3 = new List<Circle>();
        public  List<Circle> circleList4 = new List<Circle>();
        public  List<Polyline> plList = new List<Polyline>();
        public int drawAction;
        public TempGraphics()
            plList.Clear();
Jeff H
Re: Animated Block Hover
« Reply #1 on: October 26, 2010, 12:37:36 AM »
Sorry I did not mean to post.
I meant to hit preview and looking at the code it needs explanation.
So if anyone needs an explantion of what is thrown together in that mess or would like it cleaned up with an explanation I will be happy to.
Jeff H
« Reply #2 on: October 26, 2010, 01:02:24 AM »
Here it is just creating a rectangle around the block reference to clean it up with out all the hard code mess in it.
Was just seeing if it worked
using System;
       public BlockHover()
            // Create New Windows Form Control
       // TempGraphics is a helper class at bottom
            tempG = tgStatic;
           // Invoke Control
                blockHoverCtrl.Invoke(threadDelegate, tempG);// Draw Temp because tempG.drawAction == 0
            else
            System.Threading.Thread.Sleep(5000);// Sleep 5 Seconds
                blockHoverCtrl.Invoke(threadDelegate, tempG);// Erase Temp Graphics because tempG.drawAction != 0
            else
        delegate void ThreadsDelegate(object obj); // delegate
        void MainThreadProcess(object obj) // Add and remove Temp Graphics
            else
                    pLine.Dispose();
        private void HoverHandler(object sender, PointMonitorEventArgs e)// PointMonitorEventHandler
                    try
                                TempGraphics tg = new TempGraphics(); // Create new TempGraphics Helper Class
                                    Polyline pl = new Polyline();// Create new polylines to add to TempGraphics Helper Class
                                    pl.Closed = true;
                                    tg.plList.Add(pl);  // Add PolyLines
                                tgStatic = tg;
                                thread.Start();// Start New Thread
                    catch
                        tr.Dispose();
                    tr.Commit();
            plList.Clear();
« Reply #3 on: October 26, 2010, 02:04:03 AM »
Very Spiffy Jeff !!
Jeff H
« Reply #4 on: October 26, 2010, 04:58:04 AM »
Very Spiffy Jeff !!
Thanks Kerry
The idea was to figure out how to size a wheel(like the picture below) by taking the shortest length x or y of the bounding box and simulating a wheel rolling around the box.
Can any of you can come up with a algorithm for that?
« Reply #5 on: October 26, 2010, 06:06:53 AM »
Can't make time to play, but perhaps something like  ;
Polyline is curve
MyStepList shall be a 'list' of distances around the pline.
Point3d ptOnPolyline;
ptOnPolyline = pl.GetPointAtParameter(pl.GetParameterAtDistance (determineStepValueByReadingThe_MyStepList ));
I'll leave the mechanics to you   :lmao:
« Reply #6 on: October 26, 2010, 06:21:46 AM »
That may not work ... I'll need to investigate ... or you can ... sorry :)
but then again , it just might.
It's dangerous for me to just spew out half baked ideas  :|
« Last Edit: October 26, 2010, 06:32:40 AM by Kerry »
Jeff H
« Reply #7 on: October 26, 2010, 06:45:21 AM »
I was thinking along those same lines to divide the length up a multipe of 16 of the circle's circumference then ad 2 blocks one like the picture above and one rotated 22.5 then at each interval alternate blockreferences to show
Jeff H
« Reply #8 on: October 28, 2010, 03:58:44 AM »
Here is one that does a animation as long as you hover over a blockreference and does the animation for all inserted blocks of that type.
This is to just show and give ideas as the overall setup is not a good implementation
This one puts it in a while loop and adds a PromptForSelectionEndingEventHandler which is fired when you hover over an entity, once you move off the the PointMoniter fires but still will fire a couple of times in between PromptForSelectionEndingEventHandler
So a counter resets itself after 4 and sets the condition for the while loop to false to stop the animation.
It probably be better the check the objectIds but here is an idea
Click Here To See Animation
I went orange and blue for Auburn not Gators
Again this was to see if it works and slapping code together real quick.
As I am pasting code I noticed I clear list in a constructor. Go figure? That proves my point of this for a idea.
using System;
        public BlockHover()
            tempG = tgStatic;
            if (blockHoverCtrl.InvokeRequired)  blockHoverCtrl.Invoke(threadDelegate, tempG);
            else MainThreadProcess(tempG);
            System.Threading.Thread.Sleep(100);
                while (tgStatic.keepOn == true)
                    tempG.drawAction = 5;
                    tempG.drawAction = 6;
                    tempG.drawAction = 7;
                    tempG.drawAction = 8;
                    tempG.drawAction = 9;
                    tempG.drawAction = 10;
                    tempG.drawAction = 11;
                }// End While
            tempG.drawAction = 123;
            if (blockHoverCtrl.InvokeRequired) blockHoverCtrl.Invoke(threadDelegate, tempG);// Erase Temp Graphics because tempG.drawAction
                foreach (Line lne in tempG.lne1List)
                    AcadGi.TransientManager.CurrentTransientManager.AddTransient(lne, AcadGi.TransientDrawingMode.DirectShortTerm, 128, coll);
                    tempG.eraseLineList.Add(lne);
                foreach (Line lne in tempG.lne2List)
                foreach (Line lne in tempG.lne3List)
                foreach (Line lne in tempG.lne4List)
                    lne.Color = Color.FromColorIndex(ColorMethod.ByAci, 30);
                    AcadGi.TransientManager.CurrentTransientManager.UpdateTransient(lne, coll);
            else if (tempG.drawAction == 5)
            else if (tempG.drawAction == 6)
            else if (tempG.drawAction == 7)
            else if (tempG.drawAction == 8)
                    lne.Color = Color.FromColorIndex(ColorMethod.ByAci, 5);
            else if (tempG.drawAction == 9)
            else if (tempG.drawAction == 10)
            else if (tempG.drawAction == 11)
            else
                foreach (Line lne in tempG.eraseLineList)
                    AcadGi.TransientManager.CurrentTransientManager.EraseTransient(lne, coll);
                    lne.Dispose();
                tempG.eraseLineList.Clear();
                tempG.eraseLineList = null;
                tempG.lne1List.Clear();
                tempG.lne1List = null;
                tempG.lne2List.Clear();
                tempG.lne2List = null;
                tempG.lne3List.Clear();
                tempG.lne3List = null;
                tempG.lne4List.Clear();
                tempG.lne4List = null;
            Application.DocumentManager.MdiActiveDocument.Editor.PromptForSelectionEnding += new PromptForSelectionEndingEventHandler(HoverEndingHandler);
        private void HoverEndingHandler(object sender, PromptForSelectionEndingEventArgs e)// PointMonitorEventHandler
            if (tgStatic != null)
                tgStatic.keepOn = true;
                tgStatic.moniterCount--;
                if (tgStatic.moniterCount > 4)
                    tgStatic.keepOn = false;
                    tgStatic.moniterCount = 0;
                tgStatic.moniterCount++;
                    try
                                Point3d p1 = new Point3d(min.X, min.Y, 0);
                                Point3d p2 = new Point3d(min.X, max.Y, 0);
                                Point3d p3 = new Point3d(max.X, max.Y, 0);
                                Point3d p4 = new Point3d(max.X, min.Y, 0);
                                Line lne1 = new Line(p1, p2);
                                Line lne2 = new Line(p2, p3);
                                Line lne3 = new Line(p3, p4);
                                Line lne4 = new Line(p4, p1);
                                lne1.Color = Color.FromColorIndex(ColorMethod.ByAci, 5);
                                lne2.Color = Color.FromColorIndex(ColorMethod.ByAci, 5);
                                lne3.Color = Color.FromColorIndex(ColorMethod.ByAci, 5);
                                lne4.Color = Color.FromColorIndex(ColorMethod.ByAci, 5);
                                tg.lne1List.Add(lne1);
                                tg.lne2List.Add(lne2);
                                tg.lne3List.Add(lne3);
                                tg.lne4List.Add(lne4);
                            tgStatic = tg;
                    catch
                        tr.Dispose();
                    tr.Commit();
        public List<Line> lne1List = new List<Line>();
        public List<Line> lne2List = new List<Line>();
        public List<Line> lne3List = new List<Line>();
        public List<Line> lne4List = new List<Line>();
        public List<Line> eraseLineList = new List<Line>();
        public int moniterCount;
        public bool keepOn = true;
            lne1List.Clear();
            lne2List.Clear();
            lne3List.Clear();
            lne4List.Clear();
kaefer
« Reply #9 on: November 03, 2010, 03:40:59 PM »
Hi Jeff!
Thanks for the warning, but I'd like to come back anyway. I'm burning to know if it's at least theoretically possible to build a safe implementation for this type of application in the current environment.
First, the trigger. PointMonitor is it; and it is customary to restrict its activity either to one editor temporarily or to extend it over all open documents, current and future. In this scenario there is no defined end point, nothing to signal us that our animation isn't welcome any more.
Then, there's the desire to dispose with the transient lines when we are done. That might happen via time-out or when the operation  is cancelled, however that might be achieved.
And finally, if I get it right, the parallelism is marginally operative because you are running the timer from a UI thread, simulating a UI callback.
That can't be easily replaced with other async operations. I tried the TryCancelled pattern, and was pretty successfull in communication with forms controls, but wouldn't want to touch the Database. Example:
    let tickSuccess =
        async {
            while !counter < maxCount do
                do! Async.Sleep millisec
                post ... // Tick
                incr counter
            post ... } // Time-Out
    let tickSuccessCancelled =
        async {
            do! Async.TryCancelled(
                    tickSuccess,
                    (fun _ -> post ...) ) }  // Cancelled
Curious, Thorsten
Jeff H
« Reply #10 on: November 03, 2010, 08:25:50 PM »
First Off let me apologize Thorsten for posting this mess
Kerry in your reply will you edit Spiffy by changing the 'p' to a 'h' and the 'f's to 't's
This was code slapped together then if got an error changed whatever to get it working.
Trying to explain it has made me dumber and confused but see if this helps.
The first chance I get I will create a much better implementation and post it, or
Thorsten you usually have a better idea how to do things so see if this sparks any ideas.
When the "HighlighBlockReferences" command is called which is in the BlockHover class it creates a control in the BlockHover constructor and assigns it to blockHoverCtrl
        public BlockHover()
It adds the PointMonitorEventHandler  passing in HoverHandler method
In the HoverHandler method if the entity is a Block Reference Then
It creates a new instance of the Thread Class
In the Thread constructor the ThreadStart delegate is used to tell what method to process when the new Thread starts.
In the mess of code there is
When the new thread starts and the SeperateThreadProcess is called it uses the MainThreadProcess method as the Target Method in the constructor
Then creates a new instance of the TempGraphics Class and points the reference to the tgStatic variable which points to a TempGraphics created in HoverHandler Containing the lines
The TempGraphics Class has the four lists of lines(which are lines connecting the block reference GeometricExtents points)
A integer DrawAction which the value is set in SeperateThreadProcess Method and the MainThreadProcess method uses it to decide what instructions to process
tempG = tgStatic;
From VS2010 Help
Control.Invoke Method (Delegate, Object [])
Executes the specified delegate, on the thread that owns the control's underlying window handle, with the specified list of arguments
These 4 set the DrawAction number, invoke the control(passing in the delegate that the Target Method is the MainThreadProcess method , and TempGraphics Class), and sleep for 100 milliseconds
When the control is invoked from the code above the 4 lines are drawn in the MainThreadProcess matching the Drawaction and add the lines to a List eraseLineList to erase lines later
The next set runs while you are hovering over the block reference while KeepOn is true which is set true by the method called from
Once set to false in HoverHandler method it sets the DrawAction to 123 so the instructions in the MainThreadProcess Method following the else statement will erase the graphics
« Reply #11 on: November 04, 2010, 12:27:41 AM »
I feel that spiffy still works as I made no qualitative judgment   :-D
http://www.urbandictionary.com/define.php?term=spiffy
