Author Topic: CSScript (scripting engine for C#)  (Read 2245 times)
MickD
« on: August 02, 2008, 08:22:51 PM »
http://www.csscript.net/
Just thought this may come in handy for testing snippets of code to save continually re-starting acad every test.
I haven't had a good look yet but -
- Any CLS-compliant C# code (standard .cs file) can be used as a script without any modifications
Might be worth a look.
- John Carmack
- J.R.R. Tolkien
Re: CSScript (scripting engine for C#)
« Reply #1 on: August 02, 2008, 10:25:07 PM »
That looks interesting Mick .. Has potential for sure :)
David Hall
  • Automatic Duh Generator
« Reply #2 on: August 03, 2008, 12:24:47 AM »
I went and read what was there, and I'm wondering how you would use it in Acad?  From a VBScript/JScript point of view, I can see how it would work well.  If it can be used in Acad, that would be awesome
Glenn R
« Reply #3 on: August 03, 2008, 04:03:28 AM »
Interesting find Mick.
There is also Windows PowerShell which looks like it has legs
