Author Topic: Vectorize shadows  (Read 4637 times)
Eycki
Vectorize shadows
« on: August 13, 2012, 10:54:26 AM »
Maybe this is not the right place to ask.
I want to get the contour of a shadow as a 3D polyline or projection of the shadow as a 3D face.
Is there a possibility to get this done with AutoCAD and .NET?
« Last Edit: August 16, 2012, 11:55:02 AM by Eycki »
Eycki
Re: getting shadow contour
« Reply #1 on: August 16, 2012, 11:49:14 AM »
Nobody has an idea if it would be possible to vectorize the shadow from AutoCAD?
Gasty
Re: Vectorize shadows
« Reply #2 on: August 16, 2012, 12:47:14 PM »
If the shadow is an image, you should get the image and  process that image independently of AutoCAD, and use some contour detection algorithm to get the boundary of the shadow, and then, map that boundary (may be a lot of them) into a polyline or any other suitable vector geometry in AutoCAD. These algorithms are usually very sophisticated as they are implemented to recognize features in medical and satellite images.
Try this link as a start: http://www.eecs.berkeley.edu/Research/Projects/CS/vision/grouping/resources.html
Also you can try IEEE Transactions on Medical Images for state of the art in this topic.
Gaston Nunez
dgorsman
« Reply #3 on: August 16, 2012, 01:13:15 PM »
Could also look into ray tracing.  But like the other method mentioned this isn't trivial in either execution or creation.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
Eycki
« Reply #4 on: August 17, 2012, 04:57:26 AM »
I'm not looking for the rendered shadow.  There is a real-time shadow in AutoCAD which I want to vectorize by a button click. I thought maybe it would be possible to get the outlines through .NET API.
Eycki
« Reply #5 on: November 01, 2012, 07:03:48 AM »
I can't believe why there is no plugin for AutoCAD like 1001shadows for SketchUp. I could do my shadow analysis in Sketchup en export it again to use in AutoCAD but it would make things so much easier if someone knows how to make the same plugin for AutoCAD.
Video of 1001shadows: http://www.youtube.com/watch?v=NaLWS_zbP8k
Their website: http://www.1001shadows.com/en/index.html
dgorsman
« Reply #6 on: November 01, 2012, 10:19:47 AM »
The vast majority of AutoCAD users are still 2D, or limited 3D for clearance/sizes only with no need for shadows or lighting.  But isn't that one of the beauties of AutoCAD, that pretty much anybody can write one.   ;-)
I'm sure somebody here *could* but there's the whole thing of time, energy, money, existing work responsibilities...  it may take some money, or at least a few beers, to get somebody started.
try {GreatPower;}
   finally
      {MasterBasics;}
