Hi again.
Took some advice on a previous thread and took a step back. Did some reading, and managed to sucessfully compile my first project.
So now I'm onto my second project, and this one has a form in it.
I've created a short code fragment that will launch/open the form when you type the command, and a basic form with just a close button on it.
Problem is that when I go to debug I get an error:
"A project with an output type of class library cannot be started directly"
"In order to debug this project, add an executable project to this solution which references the library project, set the executable project as the startup project"
I did a bit of searching on the above phrases, and got a variety of conflicting advice from modifying some XML files in the project folder to setting a startup project using menus that don't exist...
Can anyone help me here?
p.s. I've used the autocad wizard to set up the basic project, was there a setting on that I should have used?
Edit: Just gone back to my previous project (Which doesn't have forms) and that's asking the same thing, so it looks like I've managed to break something in VS2010 express, maybe???
