Author Topic: Clearing Xrecord from Copied Block  (Read 2354 times)
kwarmington
« on: August 31, 2009, 09:19:58 PM »
If one of more blocks are copied, I want to be able to clear all Xrecord data in the copied blocks. Can anyone shed some light on where I should start?
I have looked at the CommandWillStart Event Handler to monitor for the Paste Command, but haven't been able to figure out how to access the blocks that have been pasted? I have also looked at the ObjectAppended Database Event Handler but haven't had any luck in accessing the block.
Can anyone point me in the right direction?
Thanks,
Kate
Re: Clearing Xrecord from Copied Block
« Reply #1 on: August 31, 2009, 10:17:19 PM »
How about the 'Previous selection ??
kwarmington
« Reply #2 on: August 31, 2009, 10:30:13 PM »
Wouldn't that give me the original blocks I copied not the new blocks? Correct me if im horribly wrong - I am really new to this.
MickD
« Reply #3 on: August 31, 2009, 10:56:41 PM »
A work around may be to create a special copy command to copy your blocks but I know that's not what you would really want.
What about the 'BeginInsert' event, although you are copying you are actually inserting a block ref.
- John Carmack
- J.R.R. Tolkien
« Reply #4 on: August 31, 2009, 10:58:47 PM »
Ahhh, I didn't read the problem correctly, sorry.
kwarmington
« Reply #5 on: September 01, 2009, 02:42:09 AM »
NathTay on the Autodesk discussion groups came up with the steps below. I followed them and it all seems to be working now. Thanks for everyones help :)
These are the steps I use.
1. Create global variable as ObjectIdCollection
2. In CommandWillStart Event Handler if command name is a command that can result in copies being produced instantiate the global variable.
3. In ObjectAppended Event Handler check "CMDNAMES" system variable if command is same as checked for in Step 2 add objects to global variable.
4. In CommandCancelled or CommandEnded Event Handlers if it is the relevant command process the global variable and then set it to nothing.
vnsharifi
« Reply #6 on: June 06, 2011, 11:54:01 PM »
Hello There, I have is it possible to post your code here. I have the same issue . Thanks.
Jeff H
« Reply #7 on: June 07, 2011, 09:57:20 AM »
Depending on your situation this might work
If you are creating a dictionary and adding it to the ExtensionDictionary
then set
DBDictionary.TreatElementsAsHard = false
This does not work using the AutoCAD 'Copy' command, but
will work for Ctrl+C--Ctrl+V method.
So any object 'pasted' in same or different drawing the xrecord will be empty.
****Edit***
Xrecord will not get copied instead of empty
« Last Edit: June 07, 2011, 10:05:36 AM by Jeff H »
